performance questions
ok.......when i get on the gas easy like a little under 2 grand i hear almost like a raddle but i was told it was engine knock?? i thought maybe a heat shield how can i fix this??? also one more thing if i start my car when the car is cold and go to go it wont go right away normal or tranny problem? 02 se with under 50K thanks in advance
I may have a similar problem. When you drive the car under 2K (which my wife does and complains about it! She says is preignition) the car makes a sound like a Pinging or a knocking sound. A quick stomp on the gas will make the sound go away. Will any damage occur if you were to continue with this noise.
Yes, i use 93 or higher, and I even brought it into the stealership (at my wifes request)-No problem found.
I changed out the plugs at 50K, the car has 86K at this time. Run techron cleaner every 3 months, but have used the BK stuff from Nissan once.
I am going to order a new MAF to see if it clears it up.
I was going to pick up the sea foam but didnt do it yet.
ok here we go..... step on the gas in drive it makes a loud sound like metal is rattling. but only happens under 2K RPMs im using regular gas but every few i toss the good stuff ive already done the sea foam and nothing. I want this sound gone it makes my car sound like a POS
That sounds diff. than my problem. Sorry about the hijack-the "engine knock" caught my eye. I figure my pinging if from my local gas -it may be bad
Here is whats next:
1. Replaced PCV Valve with irishs "PCV Blowby Oil Catch Reservoir"
2. Order MAF from D.B.
3. Install my new Y Pipe (when i get my leg cast off),
possibly replace o2 sensors at that time.
4. Finally get it dynoed @ SPI Pwer Excell, $85/ 3 pulls (install new MAF between runs if he lets me)
I still wonder about the coil/o2sensor TSB for the 2000 Maxima - as I recall,
one of the symptoms was excessive pinging. A google seach will pull up lots of info on pingin in our engines.
sorry about going on.....
Here is whats next:
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
So what is the problem, i don't get it
