Another source of "lost oil"
Old Jul 30, 2005 | 10:53 AM
paralyse's Avatar
I Miss My Maxima
When I had my plugs done at 60k I discovered that the valve cover spark plug tube gasket seals (the rubber things that keep oil from getting into the plug tubes) were leaking on the back head. The front was clean. There was a good amount of oil pooled up inside the back three plug tubes, though, enough to get the plugs and the coil boots wet with oil.
Old Jul 30, 2005 | 01:10 PM
njmodi's Avatar
Do I get a tax break?
This has happened to a lot of the 4th Gen VQ30DE's (myself included). Did you fix those seals yet?
Old Jul 30, 2005 | 01:12 PM
paralyse's Avatar
I Miss My Maxima
Did not correct the problem yet. Waiting on funds.
Old Jul 30, 2005 | 06:04 PM
darrick's Avatar
Dallas Nissan Enthusiast
im at 38,000 on my 5th gen mabe I should take a look at mine.
Old Jul 30, 2005 | 06:44 PM
njmodi's Avatar
It's a PITA to do the job - since you have to pull the plenum and everything in it's way off the car to get to the rear valve cover.... I did mine 3k miles ago on my 4th Gen adn one of the seals has popped completely out of the valve cover... WTF!! I did all three seals the same way, using genuine Nissan parts - so I'm not sure what I did wrong... I've just been putting off doing it again...
Old Jul 30, 2005 | 07:01 PM
traderfjp's Avatar
I've heard it's a common problem with our cars. I only had one plug coated with oil. I guess it was a tbsp. of oil. Not worth my time to fix. The plug itself was dry so I wasn't worried.
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
conansriver
Sep 11, 2015 10:26 AM
Hdnseek
Sep 9, 2015 05:55 AM
