Phantom Grip
Old Aug 2, 2005 | 10:19 AM
RacertilTheEnd's Avatar
Phantom Grip
Does anyone have the Phantom grip http://mmrusa.com/phantom1.htm in their max? If so, how do you like it?
Old Aug 2, 2005 | 12:18 PM
rmh3093's Avatar
Only gentoo powered Maxima!
that looks pretty sweet, a worth while mod down the road for me a little
Old Aug 2, 2005 | 12:35 PM
NewLoveI30's Avatar
Ooooo....I can use it with my auto
Old Aug 2, 2005 | 01:10 PM
scopium
i think HNDAETR has it on his car
Old Aug 2, 2005 | 01:37 PM
ChromeSE5's Avatar
blackbirdvq doesnt recommend this mod from what i remember.
Old Aug 2, 2005 | 02:22 PM
BewstAdd1ct's Avatar
why? i have no idea about the max, but other models seem to be getting praises...
Old Aug 2, 2005 | 02:24 PM
irish44j's Avatar
retired moderator
Quaife is the diff you want....
Old Aug 2, 2005 | 03:18 PM
phantom grip = $300ish
quaife = $1200+ish
quaife isnt for everyone, but it seems to be the best.
though in not sure if the stock unit will fit in a non-lsd trans (or if the oem unit is a quaife unit), you might try a j/y
Old Aug 2, 2005 | 03:23 PM
NmexMAX's Avatar
dot dot dot ...
What's your reason for getting an LSD?
Old Aug 2, 2005 | 03:48 PM
irish44j's Avatar
retired moderator
quaife = $1200+ish
it's just like anything for your car....you get what you pay for.
Old Aug 2, 2005 | 04:12 PM
this coming from the 'home-depot mod king'?
hmm...
so... i dont pay for my injector flushes, so what does that mean?
Old Aug 2, 2005 | 04:54 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Do you know how much a new differential costs ? bout 1000 +labor from Nissan.
Thats what you will need after 10K miles.
I had it, and do NOT recomend it.
Old Aug 2, 2005 | 05:39 PM
mdloops's Avatar
But the stock LSD from DaveB for $450 or whatever he is selling them for now. 1888-254-6060
Old Aug 2, 2005 | 06:56 PM
...meh
i get a discount on parts and dont pay labor. so... what happened? what would cause your diff to fail while several others havent had any problems?
Old Aug 2, 2005 | 07:02 PM
Mass_Media's Avatar
Mass_Media™
I would prefer knowing that I have a worth while part, then something that I don't trust. if someone on here (like irish) reccomends something more expensive I would go with the more expensive than the less....jus my 0.02
Old Aug 2, 2005 | 07:22 PM
yes well, irish seems to have that persuasion ability, hes been here quite some time and alas, i have no first hand experience with the phantom grip.
however, id love nothing more than to break a tranny so i can tear it down and build it up... honestly, id probably end up going with a stock unit.
stock units are clutch type, correct?
i prefer the torsen myself
Old Aug 2, 2005 | 08:26 PM
Who on here has had Phantom Grip ???? I don't know of anyone but Stardust and myself. I was going to put his PG in for him when I was doing his tranny+ clutch and flywheel bout year ago- we decided no to do it.
PG requires you to GRIND down the spider gears inside the diff to make the Phantom Grip plate fit in. It says SOME cars might need grinding down to make it fit, some do not. Its a UNIVERSAL design for many cars- it is NOT maxima specific.
After you remove the diff, and remove the spider gears from inside the diff, they want you to take it to a bench grinder and make the gears not as wide as stock- for room the PG requires. By doing so you weaken the gears and they will crack on you. I personaly experienced shavings from the actuall PG itself when I took my tranny apart after noticing too many metal debris in my tranny oil. I went ahead and took the PG out of my tranny, and 40K miles later I just repleaced my whole tranny with a BRAND spanking new Nissan tranny.
I highly advise you to NOT use PG in your transes, it does work, but it puts too much stress on the diff itself and you will have issues later on.
Quaiffe diff or NISMO diff for a 91-96 Altima/Stanza 5spd will work in our trannies and its 100000x better, and its reliable- more reliable than the stock diff itself.
Old Aug 2, 2005 | 08:43 PM
irish44j's Avatar
retired moderator
hmm...
....I meant mods, not maintenance
as to my "homedepot" mods...I only do them if I can do them better than buying them....
I can't make a good LSD from home depot parts
Old Aug 2, 2005 | 08:45 PM
irish44j's Avatar
retired moderator
my comment above not to get it was based almost entirely on blackbird's experiences with the PG.....plus some other problems I've seen with it on other cars...not from personal experience, by the way.
Old Aug 3, 2005 | 08:25 AM
id like to see how much material was removed from the spider gears, and an after pic of them. you guys have me intruiged now
Old Aug 3, 2005 | 08:28 AM
Parker Woodruff's Avatar
I'm still trying to find the cheapest performance modification for my car...exhaust?
Old Aug 3, 2005 | 08:31 AM
Puppetmaster's Avatar
Muchos info in the FAQs and in old threads.... please go through those instead of whoring others' threads.
Old Aug 3, 2005 | 09:17 AM
damn n00bs...
i will be using that a bit now hat im 4 posts out of newbie status
Old Aug 3, 2005 | 09:26 AM
AcerX's Avatar
damn n00bs...
And you've been here since Dec '04?
Old Aug 3, 2005 | 09:29 AM
yea yea... jsut a couple days ago, i was 'newbie just registered'
and i was like 'wtf'
...meh, i didnt post much for my 91, it doesnt give me any problems at all, but im about to buy an 02 6spd, so im making myself present.
okay, back on topic
Old Aug 3, 2005 | 09:39 AM
Progress's Avatar
It's business time.
Accelerate Quicker
Eliminate Torque Steer
Corner Faster
Improve 60' Times
I have a stock LSD in my car and I was wondering if anyone else can attribute these gains to the aformentioned part. I guess in slick conditions the LSD helps but "accelerate quicker" sounds bogus.
Old Aug 3, 2005 | 09:50 AM
2x the traction... why does it sound bogus?
Old Aug 3, 2005 | 09:56 AM
Progress's Avatar
It's business time.
Must be my tires because I can spin them with ease. I've never driving a 5-spd single wheel so I wouldn't know.
Old Aug 3, 2005 | 10:37 AM
just because you have double the traction doesnt mean that you wont be able to light em up
i think www.howstuffworks.com has a differential thing that you might take a look at.
Old Aug 3, 2005 | 05:45 PM
NiZMo1o1's Avatar
Acutally 93-97 Altima but NISMO only listed for the 93-94 .. those were the common years for OEM LSD trannys.. very few in 95's 96 change over with obdII and the 97s was a limited edition ,meaning the Altys was being retired.
only over seas the Altima Conterpart Bluebird came 92
91 Stanza only came with a KA24E no DEs yet.
I didnt realized QUaiffee made anything for Altimas.
the reason my 2cents about Altys was because I spent my whole life savings on that car before I brought a Maxima..
And Agreeing to the Topic I had the NISMO LSD in my Tranny along with 2k plus work into my tranny for boosted.
The PG really is what Blackbird says it is..I have a few Honda Buddys that completly rip apart thier Gears because of PG..
Ive seen a few Se-Rs with Qualife and never had any problems.
You do get for what you pay for. But Why do a LSD tranny unless your highly Modded? My decision for my Altima to have it was because I had a LSD and wanted to Try something different as far as Aftermarket. (the 900 price tag for the LSD was worth with it ) along with boosting at the Tracks all the time. This is what made my deciding factor for an Aftermarket LSD.
In short for the guys who question about the PG ..take it from guys that already * been there and done that* I have no experience when it comes to aftermarket "trail and error" Maxima parts..But I do when it comes to the Altimas. And some question me at the site when I made comments on parts that didnt work or worth it,Of corase theres always the kid that knows it all.
I would listen to BlackBird tho because of experince.. and from my experince PG isnt the right decision for a LSD.
Old Aug 4, 2005 | 08:19 PM
i'm a newbie on everything...I got yelled at just for telling someone he had a nice car and I liked the color...
Old Aug 4, 2005 | 09:02 PM
d00df00d's Avatar
Old enuf to pick his own gears
5spd LSDs are viscous.
6spd LSDs are helical.
Yes, Torsen-type diffs 0wn everything.
You don't get 2x the traction off the line with an LSD. You get more, yes, but not 2x more. Either way, you're definitely right that it's silly to doubt that an LSD will help traction.
Old Aug 5, 2005 | 07:41 AM
well, presuming traction is going to both wheels, you have twice the contact patch. we have to get some slip before the transfer occurs, so figure what/ 1.932x the traction
thats good info, thatnks for posting it
Old Aug 5, 2005 | 10:28 AM
d00df00d's Avatar
Yes, you're right that a LSD will put power to both wheels evenly. But for that to be twice the traction of an open diff, it would have to be the case that an open diff only sends power to one wheel at a time during a hard launch, which isn't the case. It still goes to both wheels. It just happens to go a little more to one wheel than the other.
Hence the comment that a LSD usually isn't really useful except on a highly modded car. Our open diffs do mess up the power transfer, but it's not so bad that it's seriously holding back the car's abilities.
That's just what I think, anyway.
Old Aug 5, 2005 | 11:16 AM
scopium
Old Aug 5, 2005 | 11:38 AM
Originally Posted by scopium
x2
so what about snow and ice
Old Aug 5, 2005 | 12:35 PM
Progress's Avatar
It's business time.
I never doubted that it would help traction. I doubted the better accel. times.
Old Aug 5, 2005 | 02:12 PM
mdloops's Avatar
traction is your tires ability to grip the road. What it does is supply power when an open diff does not.
Old Aug 5, 2005 | 04:21 PM
Matt93SE's Avatar
STFU n00b!
an open diff sends the power to the wheel that wants to rotate the easiest. that means you can have one wheel completely stopped and not doing ANYTHING while the other wheel is spinning its brains out.
the worst part is that it spins the easiest one to turn- so the wheel that has the traction isn't getting the torque. the other wheel is basically disconnected from the drivetrain at that point.
Old Aug 5, 2005 | 05:59 PM
one can launch harder without excessive wheelspin, thus lowering 60ft times...
would you doubt the quicker accel times of an AWD eclipse vs. its FWD counterpart?
