RT Cat rattling!!
Okay, just got back from the shop and me and my installer concluded that it is the RT cat that was causing the rattling sound..I used the installation kit provided by RT , same as the gaskets..due to its flange design we didnt' use the stock metal gaskets becaust we were afraid of exhaust leak.
anyone has RT cat,please help!!
Tim
Tim
Originally posted by Wustylez
Did you get the bolts and nuts from Nissan..how did you bolt on your RT cat without Nissan bolts and nuts??? the stock cat has threaded bolts buil in?
Tim
Tim
Help
You too, huh?
I get a buzzing sound when I first start my car. I'm not an engineer, but it sounds like something is resonating inside the exhaust system. It wasn't there before I installed the RT cat. Fortunately, the sound disappears very quickly. Does yours go away after awhile or does it keep on buzzing, Wustylez?
Re: You too, huh?
Tim
Re: Re: You too, huh?
Okay, it's been two days since i have that buzz noise,, it hasn't gone away..how long did it take you??
Tim
Tim
Call Dave at Random Technology and see what he has to say.
Re: Re: Re: You too, huh?
It seems to disappear within minutes after I start my car. But it's definitely annoying when it happens. And I wouldn't want to live with it if it didn't go away quickly.
Well, mine is little different than your situation..i dont' have any problems when starting my car , only time it happens is when i try to accelerate(hard or medium), it will rattle???
Tim
When Tim was at my place this weekend I heard the noise. It was a weird sound, kind of like if air was sucking in or being pushed out near the cat. A metal tinny/light clinking kind of sound. At least that's what I heard. I hope my description helps and doesn't confuse people
Talked to Dave at Random..no luck, he doesn't think it's the Cat, so what to do...
The sound I get is like a whirring, tinny sound. It only lasts for a few minutes after I start the car, then it disappears.
I'm not sure what's going on with your car, but I agree with punkdork. Reinstall your stock cat and see if the sound goes away.
Originally posted by WILLSE
quit talkin all this mess i had the same problem.... simple solution rip off the heat sheild on it..... problem solved!!!! same exact noise u r describing was coming from my cat too took that off and blamo no more nosie!!!
Seriously, that may be worth a try. But the problem isn't that bad in my case and I'd prefer to keep the heat shield in place.
Damn. I don't want to lose my nosie!!!
y would u want to keep your heat shield? no reason to u have plenty of heat shields under the car as it is..... just a question!!!
The heat shield under the car is the only heat shield I have. If there's another one, I'm unaware of it.
Tim
What you sre hearing is a loose "brick" inside the cat. RT is notorious for this problem. Lots of us 4th geners have had this problem, including me currently. If your rattle goes anyway after engine warm up consider yourself lucky ( mine does). If it only happens on full throttle then take it back (I hope you have the receipt).
Dave
Dave
Dave
Dave
Tim
Dave
Dave
Thanks, Dave. That actually makes more sense than a heat shield problem. The buzzing in my cat seems to go away as soon as the cat fires up. So unless it gets worse, I'll live with it as you suggest.
Should I ship it back (which will take about 2 weeks turnaround time) or just rip the heat shield off?
Tim
But mine was weird, there was no noise at all the first two days i had it installed, it started to happen after like the third day..and now it happens frequently at 1500rpm, sometimes when accelerating???
Tim
Tim
06-06-2017 02:01 PM
