2k GLE struts problem
I recently noticed some changes in my car handling: it dives after braking to the front, slightly reels after sharp corners - all in all it doesn't feel as stable as it did before. I've changed my tires about the same time to the set of Toyo T1S (was riding Nokians NRW in winter) and have no certain idea what to blame - tires or struts? Is there any easy way to check the state of the struts? BTW I have FSTB installed, it noticeably improved cornering stability but it's not related - I installed that way ago and was quite happy with results. So, any ideas?
Brake dive is normal. You should consider a RSB to get rid of some of the body roll.
To test the struts, push down on a corner of your car. It should bounce back up then down and settle... if it goes up and down a few times, they you've got a bad strut.
How many miles do you have?
Originally posted by maximadave
If your car is still under warranty take it to your Nissan
dealership...
dealership...
dvcamp
Sep 18, 2015 10:17 AM
