instrument cluster too dim?
Old Aug 5, 2005 | 10:24 PM
kobalt's Avatar
Hello all, have been away from the forums for a year or so since I got rid of my 00. But alas, I am away no more sinces I just purchased an 02 gle!
The first thing I noticed is that my instrument cluster looks very dim even at the brightest setting - much more muted than in my 00 and seems darker than the radio/hvac as well. The cluster in uniformally lit however so no bulbs out. Is there an easy fix for this or perhaps is it broken at all? Thank you in advance.
Old Aug 6, 2005 | 02:58 AM
Liquid_pjear's Avatar
Does anyone know what size those bulbs are? I need to replace one.
Old Aug 6, 2005 | 03:20 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
go to autozone... they have the bulbs.....
Old Aug 6, 2005 | 06:13 AM
kobalt's Avatar
anyone else have a dim cluster on a 5.5gen?
Old Aug 6, 2005 | 06:23 AM
boondoxmax's Avatar
I think thats just the way they are. Not as bright as other cars.
Old Aug 6, 2005 | 07:18 AM
NJ Devils Fan's Avatar
Yea, thats what I'm a little disappointed with. I remember when one of my friends got her civic, the cluster was so bright, I wish mine could look like that.
Old Aug 6, 2005 | 09:51 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Brighten it, then.
Old Aug 6, 2005 | 01:27 PM
kobalt's Avatar
Good stuff, metal maxima - perhaps I can follow your procedure. But how do you remove the cluster?
Old Aug 6, 2005 | 01:47 PM
Progress's Avatar
It's business time.
Originally Posted by Metal Maxima
What would happen if you used regular clear 194s instead of the hyper-white (blue tinted) bulbs?
Old Aug 6, 2005 | 01:56 PM
You would not get as bright a response were you to do it using anything other than a hyper-white bulb. I am going to be doing a new version of this modification next month; I will be adding 2 more bulbs in a different position and a set of hyper-blue needles, but this method would work well should you choose to do so.
Old Aug 6, 2005 | 02:00 PM
Ephraim's Avatar
well there are 5 bolts in the steering column
there are 2 bolts holding on the panel below the steering wheel
there are 2 bolts holding on the panel outside the gauge cluster
there are 3 bolts holding the cluster in
pretty much you can figure it out as you go along, i did, and it feels good to know you can troubleshoot and problemsolve on your own.
though if you do have questions while you are doing it dont be ashamed to ask.
Old Aug 6, 2005 | 02:14 PM
kobalt's Avatar
Thank you for your help
Old Aug 6, 2005 | 03:27 PM
Mang's Avatar
Can you guys tell me the OEM bulb size for the cluster lights? I only have one burnt out, but don't have the skill, nor patience to do what Metal Maxima did.
Old Aug 6, 2005 | 07:09 PM
Ephraim's Avatar
like Lontar1 said, go to Autozone, they are tons of help. just tell them your car and blah blah blah, they type in the stuff on the computer and give you the bulb size
i am not sure what the bulb size is, and i have not seen a sticky on it.
gavin68
Sep 18, 2021 12:36 PM
Max139617
Sep 6, 2015 06:02 PM
