Need Help!!! Leaking OIL!!!
Old Aug 6, 2005 | 09:08 PM
JKiMaxAC's Avatar
Ok I just got a new Motorstorm UDP. So I installed it today and the car runs great. I feel the xtra power. So after the tasting out for about 30 mins i parked it. So just a few mins ago i went out for some ciggs, and i come back and i see a not to big oil blotch on the ground. So i got under the car and checked the pullie and its leak'n OIL!!! I'm not sure to what's make'n it leak so i'm hope that some one can give me some help.. I do not want to drive the car around with a leak.. I fallowed all the instructions to taking the old UDP off and puting the new one on. But the only thing that didn't sit right with me was when i put the new UDP on it didn't go back all the way. there is like a 2mm gap from the back end of the pulley to the engine case. Could that be the problem?? But the pullie couldn't got back any further and also it couldn't cuz of the timing ring on the back of it would hit the engine case. what should i do????????
Thanks..
JIK>
Old Aug 6, 2005 | 09:12 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
the seal...did you replace it???
Old Aug 7, 2005 | 05:01 AM
JKiMaxAC's Avatar
yea i put a new oil seal.
Old Aug 7, 2005 | 06:57 AM
Ephraim's Avatar
yea that would be the problem, there is a notch in the central ring, correct? im assuming that you fit the notch up correctly otherwise it wouldnt spin, maybe try to hammer it on with a rubber mallet?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
