Weird smell coming from the a/c
when i first turn on my a/c i'm getting a weird smell that almost smells like vinager. i'm thinkin it might be the incabin filter cuz i havent changed it in awhile but i can't figure out why it would smell so bad. the smell starts to fade away after running it for a few mins. Wanted to know if anyone else has had the same problem b4 i go and spend money on a new filter. its a 2k3 by the way.
It's more likely bacteria growing in your air vents and stinkin up the place. The cheapest fix is to spray some Lysol into your vents right at the bottom of your windshield on the outside and let the vents go at full blast for awhile. Your in-cabin filter is mainly there to filter out pollen and stuff. If you haven't changed that yet, you may wanna take a look at it. Last time I did, I found tons of pine needles, leaves and small woodland creatures living in there.
Originally Posted by Iron Scimitar
I read about this on vqpower.com. Should the heat be on or is it do-able w/ cool air?
blend door on cold, a/c off, blower on the lowest position. after your done, turn it on heat for 5-10 minutes. and yes spirilis, all the air coming through the hvac system goes through the evap.
and good call on the pollen filter, however if it also happens when its on recirc, its NOT the filter
lysol kills the bacteria, but theres usually a bunch of other particles on there, smoke, pollen, dust, etc. things that get inside the car and then are attrated to the evaporator in its chilled state.
Does the 4th Gen. max have an incabin filter ? If so where is it ? I did not see it in my manual.
I have an odor in my 98 when i run the air conditioner.
Holdtight...
Originally Posted by ojman
Can someone direct me to where my in cabin filter is in my 2001 maxima and what the change procedure is? Also, is it best to use the OEM filter or are there any cheaper aftermarket ones (the OEM one is $80 from my local dealer)
http://www.innerbean.com/housecor/cabin_filter.html
For replacement filters:
http://www.courtesyparts.com/Merchan...de=B7200-00005
Don't forget to check that the drain pipe for you air conditioner is open and not clogged.
If it backs up....all that water starts stagnating. Find the hose and clean it out with a screwdriver.
It's under the car...look for a puddle of water.
thanks
I had the musty smell too, but it went away after a few weeks when I first bought my Maxima...
The worst was about 2 months ago:
I forgot to take out a frozen dinner that was in my trunk and it simmered in the sun for 4 days before the smell of wet @$$ came into the cabin during a 2 hour drive... ugghhhhh.
I almost cut out the section of carpeting in my trunk, but half a bottle of Febreez and alot of scrubbing got it out....
Now only on really hot days, the faint odor of chicken comes around when I first get into my car.... Guess I'm going to have to use the other half of the bottle in my trunk again...
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
