2k2 headlight conversion problem
Old Aug 11, 2005 | 09:29 PM
gsumax's Avatar
Ive installed 02/03 lights on my car, and for some reason, when i use my right turn signal, at random times, the high beams sometimes flicker on and then off, (only on the right side), does anyone know what may be the problem, possibly a loose ground? or I connected the wrong turn signal wire? any help is appreciated, thanks
Old Aug 12, 2005 | 08:19 AM
gsumax's Avatar
to the top
Old Aug 12, 2005 | 10:04 AM
bsetiawan's Avatar
Check your wiring work and your grounding point.
Old Aug 12, 2005 | 03:21 PM
gsumax's Avatar
i imagine its my ground because i didnt use ring terminals
Old Aug 12, 2005 | 04:31 PM
MIXXMAX's Avatar
Did you use a separate ground for the turn signals? They work much better if you do. Select a good ground point on the frame near the fender. This is what I did.
Old Aug 12, 2005 | 04:57 PM
Rob01ski
nah hes got it cross wired, if i remmber right they used different wires you probably spliced the the turn siganl wire into the high beam, lol its ok the directions arent to clear but hey thik of it as a custom mod
Old Aug 12, 2005 | 05:04 PM
ZIPPIN's Avatar
Mauja He Mauja
did u ground them properly?
Old Aug 12, 2005 | 05:08 PM
Rob01ski
Recheck your wires you might have bare wires touching, when you ground them did you remove the paint from the ground point??? If not then theirs your answer why they flicker!
Old Aug 12, 2005 | 05:20 PM
gsumax's Avatar
seperate ground? The only ground wire comes from the middle plug for the xenon... is that the one your talking about?
Old Aug 12, 2005 | 05:21 PM
gsumax's Avatar
I was thinking thats what my problem is...but i thought if they are crossed up then it wont work at all.....im still leaning towards the ground, even though both sides are grounded the same, and only the right side flicks the high beams on
also if it happens to be my ground, wheres a good spot to ground them too? right now i have them grounded to one of the headlight bracket bolts., I know thats probably a terrible place, but it is only temp
Old Aug 12, 2005 | 06:12 PM
MIXXMAX's Avatar
No, the 2K-2K1 models headlight wiring are, of course, different from the 2K2-2K3 models. If you use a different ground for the turn signals, it won't interfere with anything else in its path. If you ground the turn signal to the black wire from the harness, then you'll run into the problem of interfering with another ground from another source, such as the problem you are experiencing. When the turn signal blinks, the ground affects the other source connected to it in the same path.
Old Aug 13, 2005 | 10:38 AM
Rob01ski
Ahh plz tell me you put the ground wire underneath the plastic and bolt not in between both of them find a different screw theres plenty of them behind their.
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
Hdnseek
Sep 9, 2015 05:55 AM
mpbclutch33
Sep 8, 2015 06:21 PM
