Looking for a 2000 manual swap part list...
Old Aug 12, 2005 | 05:41 PM
FriscoMaxima's Avatar
yeah, seems like i haveno other choice but to do a swap... does anyone have a partlist that i would need to do the swap? the more complete the better. thanks guys.
Old Aug 12, 2005 | 06:00 PM
mingo's Avatar
i remember hal had it on his website before but i'm not sure if his website is still up
google "fast maxima"
i have a clutch pedal for sale off an ae maxima if u want it, and a good condition master and slave cylinder
Old Aug 12, 2005 | 06:05 PM
yeah, i am trying to find that too but i heard from someone that his list was not complete...
Old Aug 13, 2005 | 02:31 AM
how much would u want for them... pedal, adn cylinders? i assume they come with mounting hardware... thanks
Old Aug 14, 2005 | 12:27 PM
please guys, i need the list by monday so that i can fax it over to the junkyard. thanks.
Old Aug 15, 2005 | 05:05 AM
ZIPPIN's Avatar
Mauja He Mauja
Here you go BUB:
Here's the parts list:
5spd tranny (try and get the I30 LSD or Canadian Maxima LSD if possible – doubt it)
Both Manual drive shafts (if you have ABS you need specific ones, if you don't have ABS you can use ABS ones)
1 clutch kit (clutch disc, pressure plate, throw out bearing)
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
1 5spd starter
1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
1 shifter console piece (interior)
1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
1 brake pedal
1 clutch pedal
1 master cylinder
Hydraulic lines for clutch
1 slave cylinder for clutch
1 extra set of tranny harnesses (might come w/ 5spd tranny)
1 18ga wire and wiretaps
Assorted cotter pin set.
1 Manual Fly wheel
1 Manual motor mount
Tranny Fluid (GL-4 or redline is preferable)
Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
2 nuts that fit the threads on the clutch pedal.
1 bolt that bolts in the top of the clutch pedal
1 bolt that connects the control rod to the tranny
some things are missing from the list.
manual axel bracket
driver side axel
manual flywheel spacer
manual flywheel bolts (it's different for the auto)
bolts for the pressure plate. (this and the botls for the flywheel should be purchased new, it's been said on many other forums that these bolts shouldn't be reused)
manual ecu
for 5th gens, u gotta buy a manual gauge cluster trim to hide the gear selector indicator
ffcbairn
Aug 16, 2015 09:29 PM
ef9
Aug 13, 2015 01:19 AM
Team STILLEN
Aug 10, 2015 04:29 PM
