BEWARE of Throttle Body Issues!!!
Old Aug 12, 2005 | 09:17 PM
Shogunsc4's Avatar
A Nissan tech told me that numerous of Altimas and Maximas had had throttle body issues in the past and has to be replaced. I'm not sure if this is the same issue that another org'er had in which a spring would get sucked into the engine. I'm still researching. In the past 6 months (~5000 miles) I have blown 3 MAFs ( 2 "am600" and 1 "2yoo1" ). Took the car to the stealership and after 4 hours they found out that it was a fried throttle body. Estimated cost of repair is ~$1600 (TB=$1200; MAF $400 installed). Very scary!!! 3 years of ownership = 4 MAF + throttle body + NO WARANTEE.
Symtoms: car startup very weak with low ~500rpm idle. Strugglish accelerate, at times the car will not run after startup (wouldnt even rev) but after restarting the car it MAY run but in safe mode. Blowing MAF after MAF.
Dealership claimed: Intake fried the TB from "too much air" and "bad filtration" . Asked me why I didnt use their nismo CAI 'coz its covered.
Will I purchase another Nissan in the future...lol...i guess this thread answered it.
Just beware of a potential problem.
Old Aug 12, 2005 | 11:08 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Make sure to clariffy that this issue only applies to the 3.5L and 2.5L in the Altima, and 3.5L Maxima. Us 2000-2001 owners have nothing to worry bout but maybe a MAF if you still have the older design. I have 123K miles on my car and only MAFs have troubled me in the past.
Old Aug 13, 2005 | 01:19 AM
steven88's Avatar
Need A Light?
ouch...sorry to hear your losses....imma never touch my TB ever again...
a few months ago I remove my intake manifold to clean the TB+IM runners...sprayed the crap out of the IM full of TB cleaner....also moved the butterfly plate manually and sprayed the crap out of it too...wiped everything clean and let it dry for a few minutes...then put it back on and everything ran smoothly...next thing u know, I started reading up on IM+TBs for 5.5 gens and found out alot of people broke them...lol...i wont ever touch mine again...imma consider myself fortunate that nothing broke..
Old Aug 13, 2005 | 06:43 AM
boondoxmax's Avatar
I dont quit understand these whole TB cleaning. What does the dealer do when they clean your TB. I had mine done on my when they serviced it and i have know idea what they did to clean it but the car ran better ................
Old Aug 13, 2005 | 09:33 AM
BewstAdd1ct's Avatar
ive found several t/bs on car-part.com , some as low as $150.
a dealer cleaning the tb just involvs spraying a chemical on the carbon'd areas, and sometimes wiping or brushing it off. ill clean a t/b without fear of its failure.
what cleaners are you guys using?
Old Aug 13, 2005 | 10:45 AM
Nismo3112's Avatar
Custom User Title
Ouch.. I did my entire 3.5 swap for the price of your TB..
I try to stay away from the dealer BS as much as possible.
Old Aug 13, 2005 | 10:48 AM
Nismo3112's Avatar
Custom User Title
I don't understand how people are breaking their TB just by cleaning them. When I took apart a 2k2 TB, it was nothing more than a butterfly plate, motor and a few gears.
Old Aug 13, 2005 | 10:51 AM
Rob01ski
YO this only aplys to 02-03 maximas that have drive by wire throttle bodys, you know the electronicly controlled ones
Old Aug 13, 2005 | 11:02 AM
SR20DEN's Avatar
VQ Wizard
Did they give you any vaseline? Any tech or service writer that has the audacity to give a stupid answer like that should be fired on the spot. It sucks that they're allowed to get away with this crap.
Old Aug 13, 2005 | 04:49 PM
Shogunsc4's Avatar
Took it to the stealership and got everything fixed at a cost of $1680 (TB+MAF+labor). I didnt want to wait and risk losing my engine but I think I will call Nissan America to see if I can get something back...but I hightly doubt it.
Old Aug 13, 2005 | 08:42 PM
steven88's Avatar
Need A Light?
i really dont know...its electronically controlled...and they say its sensitive....o well
Old Aug 14, 2005 | 07:51 AM
bigEL's Avatar
Probably the same way people break their motorized CD trays or faceplates by yanking on them. Strip a gear (especially plastic ones), bend a shaft or plate, and the TB doesn't close complete or in the right position and the ECU throws a fit. If the motor was geared down, then you are applying a lot of torque to the plate even though you're just to move it a little bit. It's not something I would normally think about, but having read it, I wouldn't touch my TB.
Old Aug 14, 2005 | 08:54 AM
nismo_star's Avatar
2002+ Altimas,Maximas,Muranos,Quests do have TB issues, which NISSAN is addressing.
The symptom described above sounds like a TB, but MAF ??? (again..?)
A TB replacement would 99% be caused my a MIL on dash, P2135(TP Sensor)
As for cleaning the TB on above mentioned cars, you can clean it out no problem, but when your idle is at 900+rpm, get friendly with a Nissan Tech with access to a Consult II.
Especially when a MIL comes on the dash and it shows P0507(ISC System)
As for being called a stealership, its people that read one thing on a forum, and ASSUME it applies to their vehicle as well.
Numerous times I've had "NISSAN" forum members "..demand, because I read it on forums.." I show them the Nissan bulletins, which shows it does not apply to their vehicles, and it turned out be the outside influences of taking his door panel apart and breaking it. I tried to help him, by ordering the part, and letting him know I will try to have NISSAN cover the part(GRT for those who work for NISSAN), but he slammed me on my CSI survey after Cam/Crank Position Sensor campaign. At that point I refused to cover it under Nissan Warranty.
Debris in a TB can cause problems, as well as air flow meters since as mentioned, drive by wire, intergrated intake air temp in MAF, and smaller tubing in the intake tract vs a 3.0 ???(yeah its true) compare a VQ35 vs VQ30 MAF.
Old Aug 14, 2005 | 08:57 AM
nismo_star's Avatar
It sucks that some people on NISSAN forums are boneheaded at times too and should be educated on TSBs/RECALLs, the difference between them, and which apply to them.
Think of it from my angle.(Behind The Desk.)
Old Aug 14, 2005 | 09:22 AM
Gennady7's Avatar
According to my stealership here in brooklyn, my Place Racing motor mounts made my engine too rough and it caused my throotle body to break. I went back to OEM ones and found out it was cause we attempted to clean it.
Old Aug 14, 2005 | 10:14 AM
meaning, for the 02-03 maxima... yes, the electronically controlled ones.
Old Aug 14, 2005 | 10:17 AM
Shogunsc4's Avatar
hey nismo star...in your opinion do you think a call to nissan1 would help a little? Their service was good and i liked it but the BS the sevice manager gave me over the warantee is questionable. I didnt want the issue to get worse so I took it in the next day and paid for the repair. But know with a new TB, my car idles at 900 rpm with SES light on and now they say its the MAF..what do u think?
Old Aug 14, 2005 | 10:49 AM
SR20DEN's Avatar
VQ Wizard
I am fully aware of your side. There are boneheads on all sides of auto repair and unfortunately they seem to get the most exposure.
Old Oct 14, 2007 | 12:51 PM
Kryogen's Avatar
Expensive repair, damn
Old Oct 14, 2007 | 12:52 PM
NmexMAX's Avatar
dot dot dot ...
Any reason why you bumped a 2 year old thread, aside from trying to boost your post count.
Old Oct 14, 2007 | 05:46 PM
irish44j's Avatar
retired moderator
last time my MAF went bad, I told the dealer the code and they said I needed a new throttle body. Told them I'd just take a new MAF please and the guy was like "it's not going to fix anything, dude." Needless to say, a new MAF fixed the problem...
Nissan techs = morons.
Old Oct 14, 2007 | 07:14 PM
Shogunsc4's Avatar
man....are you guys trying to remind me how I threw away $1600+ 2 years ago.....I hate nissan stealership.
Old Oct 14, 2007 | 07:26 PM
SoonerFan's Avatar
Cletus
a newbie bumped it to get to 15 posts
i did the same thing earlier this year (messed up throttle body)
Old Nov 13, 2007 | 04:45 PM
antonello104's Avatar
...NYG...
If you slip the tec a 20 the TB can be reset. i clened mine and had the code and the high rpm they fixed with there computer after 5 tries and saved me big money... IT CAN BE FIXED CHEAP !!!!!!!!!!!!11
Old Nov 13, 2007 | 05:51 PM
SoonerFan's Avatar
Cletus
bad info...cant always just reset it
place your pic in your sig instead of the actual post
Old Nov 13, 2007 | 09:01 PM
AnDyMaN's Avatar
Old Nov 14, 2007 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
There have been many ways 'out' of this 'problem'. Many different things have worked for many different members. Bottom line, don't do it unless you are willing to pay the consequences, i.e. worst case scenario.
Old Nov 14, 2007 | 07:14 AM
SoonerFan's Avatar
Cletus
the dealership cant do it...but if you just give a random tech $20, he can miraculously do it
Old Nov 14, 2007 | 07:15 AM
NmexMAX's Avatar
dot dot dot ...
How bout 10 ones wrapped in a 10.
Old Nov 14, 2007 | 07:19 AM
SoonerFan's Avatar
Cletus
if only i had know that before spending all that money on a TB and ECU
Old Nov 14, 2007 | 07:24 AM
NmexMAX's Avatar
dot dot dot ...
<-------- Didn't pay a thing
Old Nov 14, 2007 | 07:26 AM
SoonerFan's Avatar
Cletus
blah blah blah and i have a MAF housing with more girth
Old Nov 16, 2007 | 09:28 AM
...NYG...
Hey sooner the teck was a friend. It is a common problem that the dealership loves to ripe you off for. the TB has it,s on computer in it it just needs to be reflashed.. i also fixed my picture problem sorry about that am new..... in fact this was the problem i had that i stumbled onto the site..
Old Nov 16, 2007 | 09:32 AM
SoonerFan's Avatar
Cletus
we all know about this.
in your case...they needed to do the relearn procedure. you need to realize that doesnt always work.
http://forums.maxima.org/showthread.php?t=394257
Old Nov 17, 2007 | 07:50 PM
...NYG...
I stand corrected but it worked for me but it did take five times for it to work. still worth a shot.
Old Nov 17, 2007 | 07:52 PM
SoonerFan's Avatar
Cletus
it is worth a try...but you acted like $20 to a tech would fix the problem. im just making sure people realize that isnt always the case
Old Jul 22, 2009 | 08:45 AM
safman16's Avatar
Help with P2135
I have a 2003 Max SE with about 105K miles. I recently had the 100K service done along with a new radiator at my local mechanic (no dealership). The other day I was driving and I lost all power to the engine. The SES light came on. I went to autozone and had P2135.
I brought it back to my mechanic and he said that the entire throttle body system needs to be replaced. It's about $199 for the parts from Nissan (rebuilt) and $150 for labor.
One concern he had was that we might need to bring it back to Nissan to get the computer reprogrammed once he installs the new TSB. Has anyone heard of this? Also, could doing the 100K service have caused this?
Thanks.
Old Jul 22, 2009 | 10:39 AM
LA02MAX's Avatar
Thanks.
$150 labor to replace the TB is ridiculous. It's held on by 4 bolts and has a couple electrical connectors attached to it. It's 100% accessible, so there's no reason you can't buy a $5 ratchet set and do this yourself.
Also, when installing the TB you are going to want to do the throttle relearn procedure. Look in the stickies at the top of the page for something like "how to reset 2002-2003 ECU" and it's a bunch of pedal pressing and key turning.
Old Jul 22, 2009 | 02:07 PM
safman16's Avatar
Thanks for the info. I'm new to this so sorry for the questions.
Is the throttle relearn procedure the same as resetting the ECU? What is the difference? I have seen the pedal pushing scenario to get the codes from the SES light. Is that what you mean by resetting the ECU?
My mechanic said that the car should adjust itself over time to the correct idle.
Old Jul 22, 2009 | 03:48 PM
SteveB123's Avatar
Mine didn't....waited 6 months, battery disconnect, idle relearn a zillion times, tied forcing it lower with plug disconnect, basicly all the tricks NOPE.
One stop at the dealer, and ta-DA.
Done.
