Cattman ypipe -bolt size
retired moderator
I might be putting on my cattman ypipe next weekend, but I will be at the parents' house, far away from the nearest auto store or home depot and want to make sure I bring all the correct hardware.
The ypipe is the Gen1 cattman pipe, by the way, and cali-spec.
Does anyone know the required bolt size (and length) - I know one of the bolts needs to be longer (to the forward pre-cat), but am not entirely sure of the length and diameter offhand. I'll try to check this week, but just checking if anyone here knows offhand!
thanks in advance.
thanks in advance.
are u talking about the bolts near the cat or the bolts near the engine, i just removed my cat this past weekend installing the PSB and i put new studs on the cat, it looks like there are plenty of room, either find a flange bolt or studs, I dont think you can go wrong if u go with slightly longer studs, there is plenty of room, you can always trim a stud down too with a saw
knight_yyz
11-01-2015 01:34 PM
