Cali spec or Federal
Old Aug 16, 2005 | 11:44 AM
03maxima1's Avatar
Originally Posted by UMD_MaxSE
First of all, if you have a 2001 Maxima, it has California/NLEV Spec emissions. If not though, you can look under the hood for a white sticker that displays emissions information. If the sticker states anything about meeting California or NLEV emissions standards, you have a Cali/NLEV spec Maxima.
The main difference between Federal and NLEV emissions is that the latter has two precats with a total of four O2 sensors versus a single precat and three O2 sensors for Federal emissions standards. In the Federal Spec emissions Maxima, you will find a single precat built into the intermediate pipe. Two of the sensors are placed before this and the last sensor is after the main cat. The Cali spec Maxima has two precats with one in the intermediate pipe and another one built into the front exhaust manifold. Two O2 sensors are located before the precats and the other two are after each of the precats. There are no O2 sensors after the main cat in this case.
Another, way is by the number of 02-plugs you have on the front valve cover clip/rack:
I was reading the above info. and was wandering which type of maxima is better to have Cali spec or Federal.
Old Aug 16, 2005 | 12:49 PM
NmexMAX's Avatar
dot dot dot ...
If you have an 02+ you don't have a choice.
Better in what sense?
They have stricter emmissions and emmissons detecing equiptment.
Old Aug 16, 2005 | 12:59 PM
SoonerFan's Avatar
Cletus
pretty much the same thing. the cali spec has one more O2 sensor. so i guess you have an extra sensor to replace. if you plan to do any exhaust mods it doesnt matter which one you have, the mods will perform the same.
Old Aug 16, 2005 | 01:17 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i realize you have a 2k3 but just for info, all 2k1 are cali spec as well. on the 3.0, fed spec will typically yield more power from y pipes since it removes both precats. fed spec do not have swirl control either which would be apart of what NmexMAX stated.
Old Aug 16, 2005 | 01:20 PM
chr0nos's Avatar
so all 02 and 03 are cali spec? i see 4 different (colored) plugs in the front...
Old Aug 16, 2005 | 01:30 PM
Puppetmaster's Avatar
Yes, they are.
Old Aug 16, 2005 | 01:38 PM
SoonerFan's Avatar
Cletus
2 plugs = 00/01 fed spec
4 plugs = 00/01 cali spec (and all 00/03)
Old Aug 16, 2005 | 03:00 PM
Stardust's Avatar
F---ing Kangaroos
Originally Posted by soonerfan
2 plugs = 00 fed spec
Fixed......
Old Aug 16, 2005 | 03:26 PM
SoonerFan's Avatar
Cletus
Originally Posted by Stardust
Fixed......
01 also has a fed spec
Old Aug 16, 2005 | 03:35 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
00-2 plugs
01-03- 4 plugs.
As for the 02 sensors going bad- I still have all of my original ones at 123K miles and they are working just fine. <knock on wood>
Old Aug 17, 2005 | 08:26 AM
Gennady7's Avatar
I have a cali spec and I changed all 4 O2 sensors about a year ago. Just did them all at the same time cause I was hoping better MPG.
Old Aug 17, 2005 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
And the point of this post is?
Thanks for the info I guess. ...
Old Aug 17, 2005 | 08:54 AM
sloppymax's Avatar
00 had fed spec and cali spec. all US 2k1 are cali spec.
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
lux97Max
Sep 11, 2015 01:12 PM
