LED Tails - Question.
Old Aug 20, 2005 | 09:03 AM
rbrown81's Avatar
But why is teh Rum gone?
All
I just purchased a set of 7443 LED bulbs to replace my stock tails from Autolumination.com . I also purchased 7440's for my rear turn signals. While comparing the bulbs, I noticed that the LED's are not nearly as bright as the stock bulbs. Im pretty sure I havent installed them incorrectly, so that leaves me with the question, Why would I use LED's if they arent as bright as my stocks?
Old Aug 20, 2005 | 09:06 AM
LA02MAX's Avatar
usually, an LED will have a lot more focused lighting, which some people believe to look good inside the housing...instead of the usual spread out lighting inside the housing, you will see a small dot in the center....that's pretty much the only reason....are the LEDs so dim that you wouldn't be able to see them during the day, though? because if they are, i would suggest taking them out because that could be a safety hazard...
Old Aug 20, 2005 | 09:11 AM
rbrown81's Avatar
They seemed dimmer yes, even looking head on at the focused Dot it seemed dimmer. I have taken them out for the very reason you suggested.
Old Aug 20, 2005 | 09:36 AM
BewstAdd1ct's Avatar
did you just get the flat regular cheap ones?
or did you get the ones that aim off to the side and back also?
Old Aug 20, 2005 | 12:23 PM
rbrown81's Avatar
I got the 7443 which are the flat regular ones.
Bugger...
Old Aug 20, 2005 | 12:27 PM
rbrown81's Avatar
Unfortunately, they dont offer the 24 LED bulbs with the wide angle for the maxima. They are an 1156/1157 size bulb that does not appear to fit
Old Aug 20, 2005 | 01:14 PM
you should try the light tower 16 led things...
on the 7440 page.
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
