compass mirror
compass mirror
how many wires are coming from the harness of the auto dim compass mirror an can you just plug the compass auto dim mirror with the two wire harness an it works or do you have to install a new harness with more wires
In case your new mirror also have temp, then you need to wire the sensor wire (this is the hard part). Since I have out side temp display already, I keep the sensor wire inside my car so the mirror will display inside temp.
I installed my Auto-Dimming Rear View Mirror w/Compass and Temp last week. I had no problem to do that at all. If you have any question feel free to ask me
i installed mine today. i did not have the auto dim to begin with. it works, but when i press the compass button it displays a C. if i press it again it gives numbers. if i keep pressing it the numbers go from 1 to 15. any idea what all that means?? it does not display north south etc...
Originally Posted by bladerunr
How do you get it to read temp? I installed a compass mirror last week and saw that it had an LCD capable of displaying temp, but it doesn't.
Originally Posted by MIXXMAX
The temp. display of the mirror needs a temp. sensor probe in order to give a readout. Either you can buy a probe and wire it directly to the mirror, or if you have auto A/C in your car, you can tap into the ambient wire which already has the probe mounted outside the car near the grille.
Huttig2009
Sep 25, 2015 03:31 PM
flu2000
Sep 8, 2015 02:23 PM
Maxilano
Aug 31, 2015 07:33 PM
