Automatic Window Problem
Old Jun 21, 2007 | 01:01 PM
  #41
shobuddy's Avatar
So am I looking for the button on the door w/the problem or on the drivers side door?
Old Jun 21, 2007 | 02:01 PM
  #42
UGAd13's Avatar
They're probably set up the same way so the door with the problem. Mine was the driver's side though.
Old Jun 22, 2007 | 07:58 AM
  #43
shobuddy's Avatar
Is anyone able to look at the pictures I posted above and tell me more specifically where I should be looking. I'll then try and get my long-fingered friend to feel around for it.
Old Jun 26, 2007 | 11:13 AM
  #44
shobuddy's Avatar
I finally found the switch and fixed the problem. My issue was that I wasn't remvoing the whole switch panel, just the handle slot so I wasn't able to see the button. Thanks to mrmj for posting the solution.
Old Jun 26, 2007 | 12:20 PM
  #45
mrmj1218's Avatar
This seems to be a very common issue... Mods, would it be an issue to make this post a sticky?
Old Jul 6, 2007 | 09:54 PM
  #46
kbohip's Avatar
I agree, as I've just spent a LONG time searching for this thread. The only problem is that even though I've found the button, my window won't go up or down at all. I think the motor may have died or something as I can hear the relay clicking when I press the switch but the motor doesn't do anything. I did hear it make a strange whistling sound though.
The car's still under warranty so I guess it's another trip to the shop. Maybe they can get the sunroof working again after the last time they didn't fix it.
Old Jul 29, 2007 | 02:57 PM
  #47
sdl13's Avatar
Last Thursday I visited my dealer because my passenger side window would go up and then come down part way. The dealer said a diagnostic would be $150 and then we could go from there and fix the problem.
This morning I joined Maxima.org, found this thread in 10 minutes and had the window problem fixed in another 15 mins.
Thanks to everyone for the great help.
sdl13
2003 Maxima SE
Old Jul 21, 2008 | 09:34 AM
  #48
kazasan's Avatar
Here is where mine was, just thought it'll help.
Please someone upload this pic onto maxima.org, before i delete it off my server.
Old Sep 2, 2008 | 07:07 PM
  #49
02_Maxima_6sd's Avatar
I also had this problem and tried this fix and it worked.
thanks fellas!!!!!
Old Sep 20, 2008 | 10:03 AM
  #50
eurospek's Avatar
So this problem has occurred on my 2003 SE back in May, and I finally attempted this fix, the longest part took in trying to locate the reset switch is inside the door panel since I first only removed the handle part but removing the whole button panel allowed to find the little button much faster. Idk how people are able to find the button without taking out the whole button panel. Followed the reset procedure and I'm a happy camper as this fix at the stealership usually costs $300.
Time to bill my parents for $150.
Old Sep 20, 2008 | 11:24 AM
  #51
02maxxxSE's Avatar
I think I may have accidentally covered this spot with sound deadening. Can anyone who's located this button take a picture of their door and circle the area for me? Thanks in advance.
Old Sep 20, 2008 | 10:14 PM
  #52
XGaSpAcHo's Avatar
yeah, i'd really appreciate that too.
Old Sep 21, 2008 | 03:54 PM
  #53
eurospek's Avatar
Well I really don't feel like taking it apart again, but the yellow dot on the door represents the area of the reset button on the inside.
Old Sep 21, 2008 | 04:52 PM
  #54
Grand_hustle17's Avatar
sooo was this fix the same for a 00-01??? i couldn't tell who's 5th from 5.5's... my passenger side goes up but wont come down using the passenger side window switch, driver side does both
Old Nov 9, 2008 | 08:58 PM
  #55
yselrod's Avatar
I was having this problem for about 4 months and it was driving me insane. I thought it should be easy to fix. Your instructions were right to the point. Thanks a $$$$$$$$.
Old Nov 30, 2008 | 11:05 PM
  #56
RPMiracle's Avatar
Your Window Regulator needs to be reset, here is the procedure posted by another member:
Driver window one touch up RESET procedure - TIP!!
With the help of the technical service manual on CD produced by Nissan on the 2002 and 2003 Maxima I now have located the quick fix for a problem I have had since purchasing my used 2002 SE a few months ago. That is the drivers door window one-touch up function for the window was not working properly. The window would go up to the top and then retreat about 5 inches back down again. This problem is due to the limit switch needing to be reset which at first I thought would be a considerable job (to take off the door panel etc.) but ended up being literally a 2 minute job as the door panel can remain in place. My dealer wanted $85 CDN for the switch reset which I knew was a rip off before I found the fix procedure myself. I know several '02 and '03 Maxima owners have had this same problem as I saw earlier threads referencing it but no-one then appeared to know the fix. Alhough this procedure is simple once you do it, my description seems long as I wanted to be a descriptive as possible since I can't provide pictures. So here it is:
Step 1: Pry the plastic cap up off the bottom centre of the door pull handle and remove the single philips screw.
Step 2: Remove the whole switch panel (in which the door pull handle sits) by prying it up from the back end either with a flat edged screwdriver or table knife (under cloth) or by hand which is what I did. It is just clipped in so should come out relatively easily sliding it up at the back and then pulling it back.
You can now see the inside of the door from where the switch finishing plate sat. You can leave the wiring all attached and simply hang the switch and handle plastic assembly to one side so you can see the inside of the door.
Look inside towards the front bottom of the door behind the plastic vapour barrier you will see a small black switch. It almost looks like a black pan screw head. This is the reset switch but there is a sequence to now doing the actual reset procedure. The switch doesn't really feel like one when you press it through the plastic liner which incidentally you don't need to cut (at least I didn't have to). It is a switch that is only on when you are pressing it otherwise when released it is off.
STEP 3: Make sure the window is closed (up) completely. Turn the ignition on so the windows are receiving power.
a) Press the reset switch (and keep it pressed in) and open (down) the window completely (manually -NOT with AUTO ONE TOUCH DOWN FUNCTION).
b) Release the reset switch. Then close the window completely (manually only - NOT AUTO UP).
c) The limit switch is now reset. Easy!!!
This procedure worked for me straight away as I hope it will for you should you have this annoying problem. The Nissan manual does caution you not to use the one touch UP-DOWN function during this procedure so be warned.
I came across this thread while searching for something else, but this is something I needed too!! THANKS!!
Old Dec 1, 2008 | 09:05 PM
  #57
RPMiracle's Avatar
Thanks again, this worked flawlessly!!!!
Old Dec 2, 2008 | 08:35 AM
  #58
BluMax's Avatar
Worked great! I used this procedure on driver and passenger windows. Thanks!
Old May 25, 2009 | 05:59 AM
  #59
Jaybone2315's Avatar
I just did this for the passenger side of my '01 i30. For some reason, taking off the switch panal was really a pain in the ***, but I got it off.
And Im still not sure how I found the switch. Its like the dealership installs it to make it as hard to find as possible. I just rubbed my hand around and found something that i could press (i wasnt sure if it was just a wire I was moving), but after i tried the reset procedure, it worked.
Thanks a ton for this advice. Just figured Id reply so that people with i30's will know it works for them too.
Old Aug 9, 2009 | 06:43 PM
  #60
TBrady26's Avatar
Just did the reset and it worked like a champ.
AWESOME!
Old Aug 22, 2009 | 02:46 PM
  #61
deo59's Avatar
You are the MAN! This has been driving me further insane and your fix worked great.
Old Aug 23, 2009 | 10:31 PM
  #62
arman's Avatar
thanks for the info. i am having that same problem as well. but also, my rear passenger side window doesent even roll up anymore.
read here for more details on it.
http://forums.maxima.org/audio-elect...-2000-max.html
please, anything will help. let me know. thanks
Old Aug 24, 2009 | 12:59 PM
  #63
nismowolfe's Avatar
I just encountered this problem 2 days ago perfect timing with this thread going out to try it now. Worked like a charm for me thanks you guys rock!
Old Sep 2, 2009 | 04:31 PM
  #64
mrjamaica98mx's Avatar
this problem started today hope this works for me!
Old Jun 19, 2011 | 11:14 AM
  #65
one_mil_2010's Avatar
Haven't tried it yet, but I'm sure it will work. Thanks
Old Sep 7, 2012 | 07:29 AM
  #66
gtech49ers's Avatar
Hey guys I have a 2005 Nissan Maxima Se and I'm having an issue with the rear door windows on both sides. I can put the windows down but I have to put the windows up by using the driver side controller. Wondering if anyone has had that issue?
Old Sep 7, 2012 | 08:19 AM
  #67
Sharon03's Avatar
I have the same problem with my passenger window. Do you think a girl can do this herself?
I paid nearly 90 bucks to have the dealer fix this. Within 6 or 8 months it happened again. It's a pain because some people don't get the One Touch function - they can't ever get the window up. Plus, you can't use the remote to close the windows. And I really don't want to go back to the dealer.
Old Sep 7, 2012 | 09:32 AM
  #68
Rochester's Avatar
They charged you one full hour labor charge for a 10 minute job. That's a shame. But now you know how that dealership operates.
Yes, of course. WTF? Get over that self-defeating, gender-bias crap, or life will run you down like road kill.
If someone ever tells you that you're "just a girl", tell them that they're just an ahole. Don't internalize it.
Old Sep 7, 2012 | 12:38 PM
  #69
Finchum's Avatar
i did this a while back. I couldn't do it the first time by feeling through the switch bezel hole, so later I pulled the door off and found it.
Now that I know where it is I can do it only by pulling the switch bezel.
Old Sep 15, 2012 | 12:17 PM
  #70
Steve Kesler's Avatar
... So here it is:
Thanks for the tip - it worked great for me!
Old Dec 16, 2012 | 01:55 PM
  #71
2001M20's Avatar
I've been fixing my own cars for more than 20 years and I'm a girl. When I did have to take my Maxima in for some major work I was giving them some tips I learned here and they offered me a job. I did this fix just now and it worked for me too. It took a few tries as I was holding down the button too long. Once I released it properly it worked. Thanks for all the great advice on this job!
Old Dec 16, 2012 | 03:01 PM
  #72
tosheto's Avatar
I had this issue on my 00 I30 and now I have it with my 02 Maxima. Going to reset it
Old Feb 14, 2013 | 01:03 PM
  #73
swheaton's Avatar
I have an 02 Maxima with this limit sw stop issue on both front driver & front pass windows and followed these instructions & WALLA!!!!!!,problem fixed!
Took me only 15-20 mins tops from start to finish!
Thanks so much for posting this fix!!!
Scott
Old Apr 24, 2014 | 09:24 AM
  #74
Castorriver's Avatar
Kudo's to the guy who posted the instructions, it worked for me too.
On my 2003 Maxima, the black switch was straight down from the switch panel, on the outside of the door behind the plastic sheeting. I had to use a long screwdriver to reach it, and it toggled to the side.
Old May 4, 2014 | 11:57 AM
  #75
spec04's Avatar
Awesome write up. Had this issue on the passenger side window, definitely a quick fix. THANK YOU!
Old May 4, 2014 | 02:07 PM
  #76
Les7311's Avatar
subscribed......
Old May 4, 2014 | 04:29 PM
  #77
Les7311's Avatar
Anyone with a pic of this reset button?
Also, does this fix works on the 05 maxima?
Old May 4, 2014 | 05:32 PM
  #78
tosheto's Avatar
You will see it when you look in there. It is hard to take a picture of it from behind the plastic.
Old May 5, 2014 | 06:15 AM
  #79
Les7311's Avatar
Was hoping not to pull the door panel back off again.....
Old May 5, 2014 | 06:18 AM
  #80
Les7311's Avatar
Found the pic on Google Pics.
Will have to remove door panel. Its a small nipple.........
