System stalled car
System stalled car
ok guys, i had my new system ripping with the automatic start on, and the car stalled, then the automatic start restarted the car. i also noticed when the car is at idle, when the bass hits hard, the RPM's drop 100rpm's and then go back up. does anyone else exsperiance this rpm drop? thanks
Originally Posted by BewstAdd1ct
ive seen it on several cars. normal, but not really good for the alternator.
also, an alternator needs to be spinning at 1500+ RPM for max output.
if hes pulling enough amps to stall the car, hell need more than a 1 farad cap.
id go with another optima in paralell...
no im not telling him to go buy a new car but the big three is upgrading the wiring to the major ground points in the engine bay... here is a good write up on it from sounddomain
http://forum.sounddomain.com/forum/u...=5;t=007801;p=
*edit* i would check the audio forum out theres alot of helpful things in there
because all of them have seen issues, electrical and driveability caused by weaksauce engine and body grounds. a little more difficult to diagnose, sometimes. the reason theyre doing it is because itll save money on warranty claims. if its a conductivity issue then he should be running 1/0 to the trunk for power and ground.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
