Disable Auto headlights
This is a little difficult to explain, so if you need further clarification, just let me know.
I'm trying to find out if and how you guys disable the auto headlight feature on the maxima's.
Most of you guys have rewired your fogs.. for the sake of be able to turn them out without your headlights. Now, when you have HID's.. you know not to turn them on for short period of time.
So, on a cloudy day... where your sensors think its dark enough to turn on the headlights, and you only want to turn on your fogs, do you always cycle through the headlights to the parking lights?
I'm hoping people actually do this and I'm not the only idiot that thinks of something so stupid.. so any help will be appreciated.
also looks like a bl/y wire from the switch going to the smart entrance control unit that signals that 'auto' position. im guessing clipping it would be the permanent answer. it goes through the switch providing a ground signal to the module.
Ya I know that... but i was hoping for a better method...
I go through a tunnel everyday for work, and I'd like to be able to turn on some light for a short period of time.. but to turn on HID's for 1 min seems useless... so that type of situation is what I'm trying to solve... plus if your driving a long time... and the sun is setting, and you want to turn on the fogs... how would you do that without cycling?
Btw, do people actually do this?
I dont know if I want to mess with the smart entrance control unit.... no way of adjusting the sensitivity of the sensor? So like if its pitch dark it turns on...
Edit: Apparently the Consult_II can do what I want in terms of reprogamming, but I dont have a clue who would be able to do this... dealership would even bother? probably not.
I run into the same problem. In morning traffic I always creep under the same overpass which is not an issue going 70 mph. However, my lights usually click on the 30 secs I under it. I trained myself to switch from auto to off before I get to this point....also when I park in the parking garage at work. As far as running the fog lights...????? I'd be interested in a solution to that as well.
http://forums.maxima.org/showthread.php?t=400024
Originally Posted by drock02
just needed the 15th post so I can start my first thread...sorry for the wasted response....
That kind of stupidity is a no no.
and will get you banned
Originally Posted by crispykid717
Isn't it damaging to the lights to do this?
how? key off, headlights dont come on. parking lights do, start the car and turn on the fogs or whatever.
i like the idea of a hidden inline switch, good call PTNR...
I have an idea that's been on my mind for quite some time. We all know that Nissan should have made the stalk so that "Auto" was below "Off" and parking lights and headlights were above "Off." What I've been wonderig is has anyone ever taken the stalk apart? Would it be possible to switch the "Off" wire and "Auto" wire so that Auto would be where Off is and vice versa? Does that makes sense? I know the readings on the stalk would then be incorrect but we would know that putting it on Auto is actually off and putting it all the way down to off would actually be Auto.
I have the same problem, i just try to remember to turn on my running lights before starting the car. I also usually run with it in the off position to not worry about the tunnels or anything else. I have been getting better at switching to just parking lights very quick tho, so to not activate the HIDS
I do love the BMW light control tho. It goes AUTO, OFF, PARKING, ON. Thats the way it should be
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
