Temporary Helper Springs
Old Aug 31, 2005 | 09:27 AM
CVicVogel's Avatar
I need to carry 5 passengers and luggage on a trip.
Has anyone seen those spring spaces that you can insert to hold up the springs or any other device that can help the springs hold the weight up.
I want something I can clip on and off without changing out the spring or shock.
thanks!
Old Aug 31, 2005 | 08:29 PM
MaximaPolak's Avatar
I drove my car to Florida from New Jersey and back on stock struts with S-Tech springs, and trunk full of luggage. I had no problem with anything. Ohh, and I had 5 people in the car.
Old Aug 31, 2005 | 10:07 PM
Larrio's Avatar
The Definitive AE Master
helper/tender/take up springs are for coilover assemblies as they feature a spring coupler and collar to provide tension when the normal spring is displaced either in hard cornering or excessive lateral movement
maybe the device you are talking about is called a different name
Old Sep 1, 2005 | 05:02 AM
CVicVogel's Avatar
Larrio
NOt sure if there is a different name. used to be metal wedges you could secure in place with an allen wrench.
Some crude ones were secured to the axle with a spring that stuck straight up to help spring the axle away from the frame. Sounds like a fast way to bend a unibody!
Hopefully, my SE springs will support it....we got a lot of weight and luggage going down with us.
thanks
Vic
Old Sep 1, 2005 | 07:48 AM
GBAUER's Avatar
Look at the bright side: if they do go, you have a perfect excuse to upgrade!
Old Sep 1, 2005 | 09:49 AM
StrongIsleMax's Avatar
Spring spacer
What I want is something like this, but for strut/spring setups:
Air lift
aw11power
Oct 10, 2021 04:57 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
