Loud radiator fan.
Old Sep 1, 2005 | 08:15 PM
DarkYDK's Avatar
Loud radiator fan.
Hey guys I just wanted to know if your engine cooling fans are loud (you know the one that turns on and off periodically to maintain engine temperatures, right behind the radiator). Anyway, mine is pretty loud. It sounds like a vacuum cleaner. So I just wanted to know if there is something wrong with it.
Also, if this is abnormal, what should I do to fix it...
Thanks a lot.
Old Sep 2, 2005 | 12:59 AM
steven88's Avatar
Need A Light?
I use to own a 96 maxima...the fans were alot more quieter than my current 2k2...and yes mine do sound like a vaccum cleaner....its real loud with the a/c on....maybe 5th gen fans are alot louder than 4th gens?
anybody else who have owned both 4th gen and 5th gen can comment as well?
Old Sep 2, 2005 | 05:25 AM
Mizike's Avatar
I noticed that my fan was pretty loud a bit ago. I was also wondering if there was anything wrong.
Old Sep 2, 2005 | 09:27 AM
o0godspeed0o's Avatar
Might be on its way out. My radiator used to be real loud and the fan used to rattle. I replaced it and it purred. Might wanna think about replacing it before it seizes on you.
Old Sep 2, 2005 | 09:59 AM
kvk2003max's Avatar
I have the same problem. When the outside temperature is high and the A/C is running, the fan gets to the fastest speed (i think) and i feel the fans vibrating which sounds like a oscillating growl (on and off). May be the dan bearings are going bad. Is there a way to just replace the bearings instead of the whole fan assemnly (i think the assembly runs about $170).
Old Sep 2, 2005 | 11:49 AM
DarkYDK's Avatar
Hmm, so you guys are saying this isn't normal?
Old Sep 2, 2005 | 12:08 PM
Mizike's Avatar
Do you guys think this is something that should be replaced under the Gold Preferred Extended Warranty?
Old Sep 2, 2005 | 01:31 PM
cabernet's Avatar
My fan used to run very quiet and now all of sudden it sounds like a vacuum cleaner too. Must be something like a bearing going bad.
Old Sep 2, 2005 | 01:53 PM
DarkYDK's Avatar
Hmm, thanks for this info. I will get my mechanic to look at it.
Old Sep 15, 2011 | 05:42 PM
DirtyD91's Avatar
I have similar issues on my 5th generation. I have noticed it getting a lot louder over the last few months and recently discovered when i have the a/c on the radiator rattles to the point of a violent shake. There also seems to be a small leak around the radiator cap..anything i can do besides replacement? Can a radiator become "loose"?
Old Sep 15, 2011 | 05:47 PM
Xpcgamer's Avatar
MIne is pretty quiet. Even sitting with the air on waiting for my daughter to get out of school. My fans where replace last year under warranty. Or least thats what the receipts say. I'd say they might be going bad.
Old Sep 15, 2011 | 06:27 PM
marky3320's Avatar
I been noticing my fan does sound like a vacuum cleaner. I never really noticed it until this summer. I guess I should start looking into a new fan.
Old Oct 6, 2011 | 08:53 PM
dhawthorne15's Avatar
Mine did the same thing last week and then I noticed the temp going up. One of the fans stopped working so now its parked until I can decide on a fan. Anyone have opinions on which way to go? I see they range from $60 on eBay to $350 at the dealer.
Old Oct 6, 2011 | 09:06 PM
03VQMAX's Avatar
Shame on all of you that replied, this thread should of been locked 6 years agoo.
Old Oct 6, 2011 | 09:36 PM
Mr. Blue Sky's Avatar
mine aren't loud....
Old Oct 7, 2011 | 10:11 AM
cabernet's Avatar
Buy the entire fan assembly with shroud. It will save you a lot of work plus the other fan will probably die soon. I bought mine from Amazon for under $100 shipped.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
