How does brake assist work?
Old Sep 9, 2005 | 10:32 PM
Y2k2maxse's Avatar
I was looking up reviews for my 2002 SE and saw that they have a feature called "brake assist" How does this work and when does it work?? Thanks. and how does it know when you need assist? (I remember seeing this on a few mercedes benz a few years back)
Old Sep 10, 2005 | 12:15 AM
tlong's Avatar
I'm not sure about the max, but on a diesel it's pretty simple. The brake assist is complimented by a vacuum assist pump. It has a diaghram inside, one side air the other brake fluid. Press the brake and the vacuum increases pushing fluid to the brake cylinder. Helping maybe twice the pressure with half the effort.
Old Sep 10, 2005 | 05:23 AM
Y2k2maxse's Avatar
My impression was that it was kind of electronic aid that helped you stop faster or something. I wasn's sure so I posted.
Old Sep 10, 2005 | 05:26 AM
silvermax2k2's Avatar
CAN YOUR SIG PIC GET ANY BIGGER????
fix it, or lose it.
from the stickys.... which you obviously have not read...
Signatures:
Signatures are a privilege extended to all maxima.org members.
Signatures may be text, images or a combination of text and images.
Signatures must conform to the following reasonable guidelines:
Sexually oriented or sexually suggestive content in your signature is prohibited.*
The maximum allowable size for a signature on maxima.org is 550 pixels wide by 325 pixels high including image and text.
You must make your own arrangements for image hosting. Maxima.org does not host signature images.
Old Sep 10, 2005 | 08:17 AM
boondoxmax's Avatar
I think some senors decide how much force to apply to either the rear brakes or front brakes based on the amount of pressure applied to the brake pad.....
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
rbaker100
Aug 28, 2015 08:11 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
