Car Ticks in Reverse, Squeaks when Turning
Anyone have any hints on what is wrong with my ride? The car lightly ticks when moving in reverse and squeaks when turning (similar to bad springs in a mattress). The ticks come from the front-end and the squeaks are from all around. WTF is wrong with my ride???
Sheki,
I see that u have a FSTB...I hear some people on the .org sayin automatic 5.5 gens make a noise when going into reverse becuz of the FSTB....could this be a possibility for yer car?
Not totally sure about the squeaks when turning....Maybe run a visual exam on your suspension components to see if anything is loose? Sorry i'm not good at this...just throwing u suggestions....hopefully everything gets worked out, cuz I know wut yer going thru right now
Originally Posted by steven88
Sheki,
Originally Posted by MAX Fa' Show
maybe you have a bad bearings in your struts thats causing the squeaking when you turn. i dont know about that ticking in reverse though
![Rotz](https://maxima.org/forums/images/smilies/rotz.gif)
When I put my automatic into reverse I get a few clean ticks also. They happen only when I first put it in gear then the ticks stop. I tried a few things and realized that I only get the ticks when I put it in drive or reverse while my foot is on the brake pedal. If I take my foot off the brake pedal and put it in gear I don't get any ticks. I don't know what my ticks are from, but I hope the tranny is ok!
Originally Posted by Shogunsc4
If thats the case...Illuminas next...lol. Opps I forgot...Nissan stole all my money. ![Rotz](https://maxima.org/forums/images/smilies/rotz.gif)
Yea I would also suggest you check out your front wheel bearings. You may also want to do a visual check on your CV boot to make sure it is not cut/torn. If it is you may also have CV joint going bad.
Lakersallday24
06-16-2019 01:35 AM
Derrick2k2SE
08-12-2015 06:47 PM
MikesChevelle
08-07-2015 05:57 PM
