Write up on how to change 2k2 6MT tranny oil?
Old Sep 11, 2005 | 01:14 PM
silvermax2k2's Avatar
I have a few days off, so I this is the perfect time to do some maint. on the car. I just did a search, and looked in the stickys, but I am not seeing anything for 2k2+ changes.
anyone have a link for me? thanks.
Old Sep 11, 2005 | 01:33 PM
steven88's Avatar
Need A Light?
http://www.innerbean.com/housecor/redline_mt90.html
there ya go
Old Sep 11, 2005 | 01:35 PM
Originally Posted by steven88
Perfect! thanks!
Old Sep 11, 2005 | 01:49 PM
Chris.s's Avatar
M/T Oil change
There are 2 10mm alan plugs on the driver side of the transmission. pull the bottom one to drain, then pull the top one to fill. Ramps or jackstands will help. Fill to the point where the oil is flush with the bottom of the fill hole (when it starts pouring out). I used 3 liters, however I think I may have overfilled with the fron end on ramps. The FSM claims 2.3L capacity
I would recommend getting a 1/2" drive 10mm Alan socket, I broke my 1/4" adapter and bent up a few other tools before I was able to crack these bolts open.
API-GL4 Gear oil or better
Drain/fill plug tourque spec: 23-28 ft-lb
Old Sep 11, 2005 | 05:46 PM
chinaonnitrous1's Avatar
Remember to Un-do the FILL plug first..........if you cant get that out after you drain it.... your gonnna be pissed
Old Sep 11, 2005 | 09:05 PM
heheh, thanks for the tip.
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
pktaske
Sep 4, 2015 08:40 AM
sdotcarter
Sep 2, 2015 09:53 PM
Lowered_a33
Sep 1, 2015 07:49 PM
