bulb behind manual AC controls
Old Sep 12, 2005 | 09:19 AM
SHouKan's Avatar
Has anyone replaced the bulb that is behind the manual AC controls before. Last night, I was driving home from work and realized that my center console looked awfully dim and noticed that 1/3 of the AC control panel was dimmed out. I thought those was LED's and don't burn out. I took the bottom panel off to see if a wire was loose b/c I just had a new radio installed but everything seems fine.
ANyone has any idea's what kind of bulbs they are and how to change it?
Old Sep 12, 2005 | 11:43 PM
c0nn's Avatar
I have the same issue... Can anyone help here?
I searched a bit and found that while some people have messed around with changing these lights... There is no write up on it. On another note it seems as though these lights are only available through Nissan?
I have the Manual control unit, any help is greatly appreciated.
Old Sep 13, 2005 | 05:27 AM
icewake's Avatar
What you have to do it take the whole thing about and take it apart. it is pretty easy really once you look at it. there is like 4 screws that hold it togehter and then 4 more that hold the circuit board or whatever to the front face. you take that off and you will see like 4 little bulbls, they just unscrew with a phillips screw driver like half a turn or something. i ordered the bulbs from nissan, but if you are thinking about changing the color or your dash now is the time
Old Sep 13, 2005 | 11:19 AM
bugbite77's Avatar
this was very helpful, thank you, now does this apply to dim bulbs or since one of my bulbs is out, its actually the bulb....not something easyer that i should check first
Old Sep 15, 2005 | 10:16 PM
SHouKan's Avatar
I also tried searching hard for a write up with no luck.. i'm gonna try to take it apart this weekend to see whats going on
Old Sep 16, 2005 | 08:30 AM
c0nn's Avatar
Sounds good, I may do the same... if not I look forward to any info you provide.
Old Sep 16, 2005 | 08:43 AM
maximo-SE's Avatar
hm... i wonder if these might be 74 bulbs which were the same ones I used to change the ignition ring color on the steering wheel. I bought more so I can change the lights above my ashtray.
Old Sep 16, 2005 | 10:41 AM
c0nn's Avatar
Where did you get your bulbs? I will let you know what bulbs are in the AC controls as soon as I get to the project.
Old Sep 16, 2005 | 10:59 AM
maximo-SE's Avatar
i got them from autolumination.com. i've done business with them a few times. I have nothing but positive feedback for them. i think the guy also runs ebay auctions for his bulbs. just ebay 74 bulbs.
Old Sep 16, 2005 | 08:34 PM
SHouKan's Avatar
ok.. i'll do them tomorrow and let you know c0nn. I'll see if I can take pics in the process if I have the time.
Old Sep 16, 2008 | 06:18 AM
phatboislim's Avatar
which bulbs are used for the a/c controls..it was never said..it was only said that 74 bulbs are used for the iginition ring
Old Sep 16, 2008 | 09:13 AM
Nelsito65's Avatar
I replaced those on my 2000 maxima recently. There are 3 bulbs that illuminate the a/c control itself. The part number is 27545-1W600. I purchased them from the local Nissan dealer for $3.83 a piece.
Old Sep 16, 2008 | 09:17 AM
I'D LIKE TO DO AMBER FOR MY A/C CONTROLS...NO GENERIC PART NUMBER? IS IT BULB197?
Old Sep 16, 2008 | 12:21 PM
rolldog1's Avatar
2K2 SB Max
Check the 4th Gen info for a write-up on changing bulb colors. I replaced them on my old 4th Gen with stock ones from Nissan, although I got charged $5 each for mine. I couldn't find the aftermarket replacements but that doesn't mean they aren't out there. I think there are also colored rubber things (that sounds bad) that can fit over the top of the bulbs to change the color. Good luck.
Old Sep 16, 2008 | 01:04 PM
I JUST NEED THE BULB CODE...I CAN GO FROM THERE TO FIND WHAT COLOR I WANT. I MEAN EVEN THE PARTS STORE HAS THE SAME 197 BULBS FOR LIKE $2...I USED THOSE WHEN I WENT AMBER ON MY INTEGRA DASH
Old Sep 16, 2008 | 02:09 PM
knight_yyz's Avatar
Toolie
#74 bulbs, or you can buy the neo wedge bulbs from autolumination.com
Old Sep 16, 2008 | 02:23 PM
neo wedge bulbs?
Old Sep 16, 2008 | 02:30 PM
knight_yyz's Avatar
Toolie
http://www.tradekey.com/ks-neo-wedge-bulb/ they look like this
meccanj98
Sep 16, 2015 07:23 AM
BrandonCause
Sep 14, 2015 10:41 PM
kjlouis
Sep 14, 2015 11:22 AM
kadespraggins
Sep 14, 2015 12:04 AM
minsbang
Sep 11, 2015 08:48 PM
