Ignition lamp went off
Old Sep 12, 2005 | 12:05 PM
Nomad's Avatar
guys does anyone know whre's fuse for ignition lamp (key-ring) located it's went off recently. I checked the lamp it self but seems like it fine. I w/another lamp but still it doesn't work
Old Sep 12, 2005 | 03:35 PM
BewstAdd1ct's Avatar
its the r/g wire out of the smart entrance control unit pin 50and the r/y return at the SECU pin 30. its PROBABLY the bulb, even though it doesnt look bad. if you replaced the lamp already then you can do some more checking, like power trace at the connector, pins. look for chafed wires. if the trunk lamp and door step lamps work then its not a power issue...
Old Sep 12, 2005 | 04:32 PM
Nomad's Avatar
ok here's the deal i changed lamp and now it wouldn't go off even when i lock the car thru key fob also it doesn't go off if i run the engine and drive. Before it did. Shoot what could be a problem?
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
03VQMAX
Nov 10, 2015 03:39 PM
msellas
Sep 23, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
