Timing question
Old Sep 13, 2005 | 09:15 AM
Jay_pee99's Avatar
Timing question
If i had my timing advanced and then my battery was disconnected for a long period of time, will i have to get my timing advanced again?
Old Sep 13, 2005 | 09:22 AM
NmexMAX's Avatar
dot dot dot ...
No, it should be fine, the only way it resets is with the consult II.. if you're really paranoid you can have it verified/checked by a Consult again ...
Old Sep 13, 2005 | 09:58 AM
Jay_pee99's Avatar
yeah, but Nissan are trying to make me pay $98 to check it again. I was hoping someone new of hand.
Old Sep 13, 2005 | 10:02 AM
chr0nos's Avatar
it will not reset on 5th gen maximas.
Old Sep 13, 2005 | 11:00 AM
AcerX's Avatar
Just go to Autozone and let them check for free. Tell the Nissan people your doing it also. Check the facial expressions when you say it.
Old Sep 13, 2005 | 11:49 AM
NmexMAX's Avatar
dot dot dot ...
Err ehhh They cannot check the base timing at AutoZone, only the codes ... They (AZ) DO NOT have a Consult II ...
Old Sep 13, 2005 | 12:55 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
they might have a handheld obd2 which depending on model can check base timing. i have seen a few different parts places carry different models. some just check codes and others are full functioning but of course if you want to change timing then consult 2 is a must. i happened to have an old laptop from college and just put it to use with harrison software from odbscan.net
Old Sep 13, 2005 | 01:30 PM
Deckdout2's Avatar
Play with my balls
hey, can you change the timing in mine and kimberly's car with that harrison?
Old Sep 13, 2005 | 01:54 PM
GBAUER's Avatar
Jay-pee. Take it to Fred-neck Nissan. It'll save you about $15 bucks or so. PM me for my phone number and we can split the savings at the brewery up there.
Old Sep 13, 2005 | 03:35 PM
NmexMAX's Avatar
dot dot dot ...
yeah I forgot he was only trying to verify and not actually change .. my bad ...
Old Sep 13, 2005 | 03:53 PM
sloppymax's Avatar
negative. need a consult 2 to do but that shop in indian trail will do it but not sure what they charge. it only about 2 miles from my house but IIRC bladerunr went there and they wanted 50. i think he ended going to a dealer in rock hill and they did it for 20 or 25 bucks. the place in indian trail is niss-tech and they bought the consult from what was independence nissan.
Old Sep 13, 2005 | 04:58 PM
Deckdout2's Avatar
Play with my balls
yep, when i had my 4th gen back in 99 i always took my car there to have them work on it. i was close to the manager jeff there. i'm gonna try to take it there then, if not i'll go to rock hill.
thanks
Old Sep 13, 2005 | 05:00 PM
irish44j's Avatar
retired moderator
Jay, we just went down to brown's fairfax Nissan and slipped one of the techs a little cash to do it out at the back door of the garage. Most dealers will not do it "on the books" (trust me, I tried 4 different local ones) or will charge you alot.
Old Sep 13, 2005 | 07:24 PM
MaxArt's Avatar
Just a quick (shaggy dog story) check in on the timing issue. Was involved in a lot of the technical discussions back in the spring and summer (Hey Irish - hope I provided some informative stuff about timing theory and manufacturers generally compromising a little and therefore the 15 btdc on the Max can probably be advanced a few degrees without problem). Well, having talked myself into it, I actually asked several dealerships to advance my timing to 17, and was given various "can't do it's" and "you'll harm your engine etc."
Had the "unfortunate" experience of the service engine soon light coming on recently on a rainy Friday afternoon. (coincidentally a few miles after 10,000). Remembered there was a Nissan dealership on the way home that I had never visited before (and not wanting to drive with the light on all weekend) I decided to stop in and ask if there was some mileage link I didn't know about and if something needed to be reset. They had me pull right in -The tech hooked up the Consult - first question, "Is your gas cap on tightly?" Sure enough I had trapped the retainer strap under the edge of the cap and it hadn't tightened right - luckeeee! While he was dropping the code, I asked if he could check the idle speed and timing - I thought they both might be a little low. He bumped the rpm and said my timing was at 14. He readily bumped it to 17 for me. And we were right all along! Better idle, better performance and shifting, and better gas mileage just in time for $3.59 a gallon. Dealer name in Clarksville, MD area available upon request.
Old Sep 15, 2005 | 06:27 AM
Jay_pee99's Avatar
Thanks for the info guys. I will hopefully have this done this weekend! Gbauer i will be sending you a pm
Old Sep 15, 2005 | 07:10 AM
ABS's Avatar
ABS
I'm pretty sure that the base timing at idle will show an advance by just using a traditional timing light and the "wire loop" on the engine as shown in the ESM.
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
mikekay
Aug 10, 2015 12:52 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
