aiming 00-01 lights lower
Old Sep 18, 2005 | 07:04 PM
roll4life's Avatar
Anyone have a write up for this or even just some instructions? I tried searching and i can't find anything.
thanks guys
Old Sep 18, 2005 | 07:14 PM
Puppetmaster's Avatar
Isn't there just a **** of some sort that you can turn (sometimes with a Phillips screw driver) to change the angle of the headlights? It should be on the back of the housing.
Old Sep 18, 2005 | 07:58 PM
roll4life's Avatar
haha ahhhh ive tried turning all the "*****" and using a phillips screw driver but i don't see anything moving inside the light
Old Sep 18, 2005 | 08:58 PM
E55AMG2's Avatar
Wat
youd need to have the lights on, pointed at a wall, with the car on a level surface.
Old Sep 18, 2005 | 09:13 PM
roll4life's Avatar
i kinda thought about that..but if i put the lights back on the car i probably cant reach any of those screws/*****..unless you mean just holding the light with my hands and try turning the screws?
Old Sep 18, 2005 | 09:43 PM
E55AMG2's Avatar
Wat
It should be an 8mm plastic nut with a slot for a screwdriver. If you have a small ratchet, you can do it with the lights in the car.
Old Sep 18, 2005 | 09:58 PM
ChromeSE5's Avatar
the lower ones, i fturned clockwise, showed lower the headlights while the top ones should change the horizontal angle of the headlights
Old Sep 19, 2005 | 12:00 PM
roll4life's Avatar
oh man i gota be missing something here..there is no 8mm plastic nut on the back of the 01 headlights all i see is a long metal screw and some plastic things but no nut..or im just crazy.i will take a pic of the back of the headlight and post it here..this is rediculuss
Old Sep 19, 2005 | 01:28 PM
ChromeSE5's Avatar
its a philips screw also with an 8mmm head...
Old Sep 19, 2005 | 03:32 PM
SHouKan's Avatar
i only see the long metal screw also.. I thought that was it.. i guess not...
Old Sep 19, 2005 | 09:20 PM
roll4life's Avatar
ill try doing this soon and post the results
vingodine
45
May 21, 2016 12:46 PM
ah2002
Mar 9, 2016 01:42 PM
homeyclaus
Sep 3, 2015 06:15 PM
beboski
Aug 16, 2015 05:23 PM
