Maxima techs and gearheads, please help me...
Old Sep 18, 2005 | 11:59 PM
FriscoMaxima's Avatar
i need help determining what is wrong with my car, i will do my best to describe the problem...
it is a 2000 automatic adn about half the time, when i put it into drive or reverse it starts shaking as if the engine is about to die out. when i give it gas, the car takes off slowly as if it has a 50hp engine under the hood... but then sometimes it goes back to normal all of a sudden. gets a boost of power after around 2500-2700rpm. does anyone have any idea what the problem might be? thanks
Old Sep 19, 2005 | 12:12 AM
5thgen2nr's Avatar
Number of things...dirty TB, dirty fuel line/filter/injectors, MAS going bad...
Old Sep 19, 2005 | 12:29 AM
could it be my VIAS?
Old Sep 19, 2005 | 05:50 AM
alicious's Avatar
the org...not what it was
sounds like it could be the MAF , no SES lights or anything?
Old Sep 19, 2005 | 12:07 PM
i do have an SES light and i am planning to get the codes pulled up on wednesday. how much does a MAF usually go for sale? thanks guys
Old Sep 19, 2005 | 12:21 PM
Charcoal95GXE's Avatar
seriously man, this is gonna sound silly but just for ****s and giggles...check and make sure the mafs is plugged in..
-Brian
----i had the same problem with my 95 and its cuz i left it unplugged on accident.
Old Sep 19, 2005 | 12:44 PM
alicious's Avatar
between $75-$100
get in contact with Dave B
Old Sep 19, 2005 | 01:34 PM
-Brian
yeah, i did check it a few times adn it seems to be plugged in alright. the weird thinng i do not understand is why the car drives like **** only approximately half the time. i just came back from school, and i obviously drove there, and the car worked fine... no shaking no nothing, the SES is still on though... i mean if a MAF was gone, wouldn't it make sence for the car to drive like crap ALL THE TIME not on random occasions. i cannot notice a pattern in the switches from normal to crappy driving. sometimes i start it up, adn from the moment of the start it shakes like hell, but on other occasions, it works as smooth as a swiss watch. in some cases it swtiches back and forth during the drive... damn, dunno what to do, gotta pull those codes... thanks guys
and btw, who is DAVE B?
Old Sep 19, 2005 | 02:56 PM
99 SE-L
Dave B is the parts manager at southpoint nissan he gives us orgers a discount, look in the sticky's for his number.
Old Sep 19, 2005 | 05:34 PM
BewstAdd1ct's Avatar
no, for some reason the MAF can fall in and out over the sensible range... a fluctuation, really.
could also be coils. a secondary ignition misfire will show itself moreso under load, and when you get at a higher engine speed, less load, the misfire goes away and you have a car again.
Old Sep 19, 2005 | 06:27 PM
GBAUER's Avatar
Autozone pulls the codes for free. If it's a coil, they'll even tell you which one.
Old Sep 19, 2005 | 06:31 PM
SoonerFan's Avatar
Cletus
$100 says its the MAF.
if someone takes the bet, i'll give you my address to send me my money
Old Sep 19, 2005 | 07:21 PM
Stardust's Avatar
F---ing Kangaroos
What do you know about the 3.0? You have a 3.5
Old Sep 20, 2005 | 10:06 AM
I have a CAI on my car so i really think that it is the maf. i drove with that intake all winter (well, a california winter) and been through a few thunderstorms on freeway with it. i would not be surprised if that sent my MAF south... thanks for the input guys... love you all (in a straight way)
Old Sep 20, 2005 | 10:09 AM
as a matter of fact i do experiance a bad shaking when the car is under load accompanied by a disgusting power loss. as soon as the autotragic downshifts, and rpm go up, the car almost wants to burn rubber...
Old Sep 20, 2005 | 11:45 AM
MAF.....
DaveB..is kinda like...your daddy
Old Sep 20, 2005 | 02:42 PM
dvanorder's Avatar
Agreed--get the codes first and post them here. Lots of us have 2K's and have struggled with performance because of parts going bad but not completely failing. The MAF is a tricky beast if it's still measuring, but just not measuring correctly. With my Vette, if I fail the MAF using tuning software the car switches to the low octane table and runs in SD mode. Runs fine, just less advance and fueling requirements rely primarily on MAP and a lookup table. I would think the Max does something similar--with a hard failure. What I would give to have a version of HP Tuners for the Nissan 3.0 so I could find out!
For grins, has anyone ever mapped out the Max MAF curve using scanning software and compared it to what the PCM has?
Old Sep 20, 2005 | 02:49 PM
AcerX's Avatar
MAF.....
What?? I wish Dave was my dad, do you realize how well tuned my auto would be!
But seriously, Dave is the guy to call for your maxima part(s) inquiries.
Old Sep 20, 2005 | 06:25 PM
the p1320 that the 5.0gens are plagued with wont specify which coil
Old Sep 21, 2005 | 12:48 AM
5thgen2nr's Avatar
I'm going to halfway hijack this thread because I just remembered to ask this question...does it matter where your MAFS is in the airflow stream? Because I think when I made my home depot WAI for my max I had it in such a way that I had to reposition the MAFS closer to the TB...does it really matter?
Old Sep 21, 2005 | 04:37 AM
dvanorder's Avatar
Everything I've read indicates the MAF should be closer to the intake than the throttle body.
Old Sep 21, 2005 | 04:56 PM
nismo_star's Avatar
Got Codes ?
Old Sep 21, 2005 | 05:41 PM
Originally Posted by dvanorder
Everything I've read indicates the MAF should be closer to the air filter than the throttle body.
edited. intake=intake manifold.
plz dont confuse ppl by calling a cone filter an intake
03VQMAX
Sep 25, 2015 04:19 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
