Cattman Fast Cat question.
Old Sep 20, 2005 | 02:11 PM
ecko51's Avatar
I just got my Cattman Fast-Cat for a 2000 Max.
Does it matter what dircetion it goes?
I know the heatsheild goes up but the canister is offset .
I'm not sure it should favor the front or back.
Thanks, Mike
ps. the quality of this thing is great.
3/8 thick flanges, good quality Stainless and great welding.
It looks like a test pipe with a bubble in it (some kind of honeycomb filter)
Old Sep 20, 2005 | 02:13 PM
03on18s's Avatar
does that still allow you to pass emissions?
Old Sep 20, 2005 | 02:14 PM
SoonerFan's Avatar
Cletus
hell no.......
Old Sep 20, 2005 | 02:47 PM
nicks79's Avatar
then what is the need for it???
Old Sep 20, 2005 | 02:52 PM
jimmycapp's Avatar
Indeed
Old Sep 20, 2005 | 06:45 PM
03on18s's Avatar
the custom maxima and warpspeed performance cat's will still allow you to pass right? they aren't test pipes, supposedly just better flowing cat's.
Old Sep 20, 2005 | 06:51 PM
NYPD-Arnold's Avatar
Z
Originally Posted by soonerfan
hell no.......
Hell yes; in NYS at least. New inspection regulations don't require smog/exhaust test anymore. Pass or fail is determined by OBD-II codes stored in ECU. If you have no codes pertaining to oxygen/air issues, you pass.
Old Sep 20, 2005 | 10:26 PM
SeaFoam2DMax's Avatar
Oh hi....
I just found this out, it is a beautiful thing. I was all worried too.
Old Sep 21, 2005 | 12:43 AM
5thgen2nr's Avatar
So in New York they don't go by the sniffer or anything, they just run a code reader on your ECU to see if they pull anything up? Where do I sign up for this kind of smog certification in California!?!?!?!?
Old Sep 21, 2005 | 03:14 AM
ecko51's Avatar
I was told that this is a high flow cat and will pass bith visual and smog test as long as there are no other problems.
It has a canister with the honeycomb stuff in it.
Old Sep 21, 2005 | 04:35 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
as long as it is a true cat and not just a test/racing pipe then you will be fine. the problem comes with fed spec 2000s put a test pipe in and they have an o2 sensor behind it that detects it is missing.
Old Sep 21, 2005 | 06:13 AM
ecko51's Avatar
I have a 2000 Cali-spec and it is a true Cat.
It kinda looks like this but much thicker SS and with flanges.
It'a also a direct fit no a universal. The flanges are rotated like the OE.
http://www.performancepeddler.com/de...T_ID=SUP200605
Old Sep 21, 2005 | 06:44 AM
sloppymax's Avatar
should be good to go then. cat is very easy to swap out.
Old Sep 21, 2005 | 02:09 PM
Champ2433's Avatar
I've got the Cattman Fastcat. You should install it with the offset narrow end towards the y-pipe, with the heatshield facing down. This is so you dont light grass or something on fire...You will have a break-in period where you will hear the cat "clicking" for a few weeks at times.
I am pretty happy w/it, its going to be slightly louder than stock, especially because it's directly under the front seats. Also, while the cat itself is stainless, the flanges are not and do rust. I suggest using stainless bolts if they did not come with your cat...All in all though, it's a pretty good product.
Old Sep 21, 2005 | 03:06 PM
GBAUER's Avatar
I bought one and put it on about a month ago. Direction doesn't matter. BTW: it helped a little, but I think most of the kick i got was from the 17 degree timing advance in my 3.5. I replaced my cat because I killed the stocker. Bad kitty. Bad, bad kitty...
Old Sep 21, 2005 | 07:45 PM
Epacy's Avatar
Unsuccesful STL Coordinator
hell no.......
Actually it does.
Old Sep 22, 2005 | 09:47 AM
^^^Yup. That's what Brian told me too about installing it. Months later, my Cattman Fastcat "clicks" when I turn the car off. I suppose it's from the cooling of the hot pipes. (expanding/contracting) After 5 minutes, it goes away.
Old Sep 22, 2005 | 04:15 PM
Snolife's Avatar
What we have here is a failure to communicate
I will be getting one when his headers become available. Cant wait!!!!
doctorpullit
Mar 29, 2016 11:08 AM
maxinout93
Oct 31, 2015 02:04 AM
pears
Sep 18, 2015 05:25 AM
