Alternator belt adjustment
Old Sep 24, 2005 | 07:00 AM
woosh's Avatar
My alternator belt needs adjustment (tightening a bit) and I was wondering if ppl could share their techniques or proper method on getting it adjusted close to spec (3.7 - 4.1mm deflection).
starting with tensiion adj and idler adjust in their current position, should I:
A) tighten tension adjust, then loosen idler and re-tighten idler.
B) loosen idler idler nut, tighten tension adjust and re-tighten idler.
thanks
Old Sep 24, 2005 | 07:03 AM
GBAUER's Avatar
thanks
loosen idler nut then tighten belt, then tighen idler nut. I helped a buddy of mine on his 4th gen and had to do it that way. a real PITA because the nut was tight.
Old Sep 24, 2005 | 08:24 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
http://www.forums.maxima.org/showthread.php?t=430847
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
