help.....socket stuck in spark plug hole....any ideas?
decided to change out my plugs before the races tonight, and i got my spark plug socket stuck in the access hole to the spark plug......it just won't stay attached to the extension.....i tried to pull it out with needle nose pliers, and i can't get a good enough grip on it.....any other ideas???
this sounds so stupid.....
Originally Posted by Metal Maxima
Magnet & fishing wire?
Originally Posted by GBAUER
Do you happen to have a welder, a roll of duct tape and a can of tuna on hand? If you do, I can tell you how to get it out while eating lunch.
no welder or tuna, and i can't reach down far enough to duct tape it....
i did get some jb weld and put that on it....waiting for it to cure, then i'm gonna yank the **** outta it and try and get it out. also gonna try and spray wd-40 down there and see if i can get it lubricated.....
hopefully i can get this done pretty quick and still make it out to the track....
Did the tuna help?
no, i jb welded the socket to the extension and sprayed some wd-40 down there. a little turning and pulling and it was outta there....used a different socket, and got them all changed out.
really appreciated that nissan did a good job of tightening up the bolts on the rear coils when they replaced them.....i was able to unscrew them by hand....
OMFG i changed the spark plugs om my skyline ZOMG number 3 and 4 are bastards (its a RB30e) you have to take teh intake piping off and use a "wobble extension"
WOW NISSAN you did a good job at making me take 45 minutes to change 6 plugs
be happy you dont have to take the intake manifold off
all i use are wobble extensions, and i dont use spark plug sockets, i cant stand the o-ring plug retainers and the time it takes to fight with them, albeit not that much.
Originally Posted by Trance Artur
Like he said. At my shop at work, the magnet is a great tool for situations like this.
wouldn't have worked....it wasn't just sitting down there, it was stuck in the hole....the diameter of the socket was too large, and it got stuck in the hole. i did, however, use a magnet to get to the screws that held on the rear coils....my fat hands couldn't have reached if there was a million dollars down there!!
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
