sign of a blown strut?
Old Sep 27, 2005 | 02:58 PM
chr0nos's Avatar
i put h&r springs on about a month ago, and recently i noticed that the passenger rear tirewell sits about 3/4-1 inch lower than the driver's rear.
is this a sign of a blown strut? when one side is noticably lower than the other?
Old Sep 27, 2005 | 03:00 PM
Jime's Avatar
Oil leakage is a sure sign, check for dampness around the seal and below.
Old Sep 27, 2005 | 04:07 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
do the bouncing test to check it out.
Old Sep 27, 2005 | 04:43 PM
soundmike's Avatar
Very sound, Mike
My OEM struts never leaked and bounced just fine with the "bounce test". A sure indication it's blown is the car bounces almost endlessly after hitting bumps. If you already have the struts out, compress it manually and see if it rebounds or just sticks to the compressed state.
Old Sep 27, 2005 | 06:54 PM
BewstAdd1ct's Avatar
the absorber portion of the strut wont affect ride height.
Old Sep 27, 2005 | 06:58 PM
MAX Fa' Show's Avatar
even if you have blown struts, the ride height should be the same, if you are on level ground that is. maybe a spring coil is not sitting on the spring perch. that has happened to me in my 510 once, so maybe check that out.
Old Sep 27, 2005 | 08:02 PM
chr0nos's Avatar
hmm, ok. thanks for all the ideas. tokico blues should be here tomorrow, and the install is prolly coming this weekend.
the car seems to ride fine, and does not bounce out of the ordinary. maybe the spring is turned funny on that side...
it rides like *** on stock struts, hopefully the blues will give it some more give, like the oem suspension.
Old Sep 28, 2005 | 08:39 AM
lowincash's Avatar
No More Maxipad
i just swapped out my stock shocks to the tokico blues and felt a lot smoother. my stock shocks were very worn that they don't even come up after you push the stick in. new shocks pop back out real fast and is harder to push in...also, i think my worn front shocks made the front a bit lower because after i got the blues installed the front seem higher by like 1-2 finger gaps =/
Old Sep 28, 2005 | 08:55 AM
chr0nos's Avatar
how many miles you got on stock struts?
Old Sep 28, 2005 | 09:34 AM
lowincash's Avatar
No More Maxipad
it got like 83k on the struts...well i bought this car used with about 80k on it and i'm guessing the previous owner did not change anything on it. i'm just happy now the ride is much smoother
Old Sep 28, 2005 | 11:11 AM
nicks79's Avatar
mine are still OK at 110k miles.. wow
Old Sep 28, 2005 | 03:26 PM
chr0nos's Avatar
i just received the tokico blues. i think they sent me wrong parts. i got HB3102 and HU2905. tokico's web site states that this is for a 4th gen max, and 5th gen uses HB3188 and HU2943.
can anyone that has bought hp blues for their 5th gen confirm which part numbers they received?
Old Sep 28, 2005 | 03:34 PM
00SEMAX19's Avatar
Struts/shocks will never affect ride height. Ride height is controled by springs only. You may have a bad spring, or just one installed incorectly. If everything looks right and it still has an uneven ride heights (more than a 1/4 inch) then you should be able to get H&R to warrenty them out. Good Luck
edit:The strut mounts can also cause some ride height differences if they are worn
Old Sep 28, 2005 | 04:04 PM
lowincash's Avatar
No More Maxipad
i got HB3188 and HU2943 that's what it says on the box.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
