Just installed my MAF and guess what ??
Old Sep 29, 2005 | 09:47 PM
  #41
spiromax's Avatar
Seoul Man
Originally Posted by BewstAdd1ct
i cleaned hundreds of e-throttle bodies and have never had a problem. and thats why theres a learn procedure. perhaps it wasnt entering learn correctly...
do you have the old t/b still?
I performed the learn procedure properly, but the idle would never stay where it was supposed to. A few days later, the high idle would throw a code. I finally took it to a tech who's an Org member, and he couldn't set the idle properly either, even with the Consult II. I don't know if mine is the old TB or the new one. He replaced my bad one with another used part, so it could be another old one for all I know.
Old Sep 30, 2005 | 04:45 PM
  #42
BewstAdd1ct's Avatar
interesting...
do you have your old one still?
Old Oct 3, 2005 | 09:22 AM
  #43
silvermaxd's Avatar
ordered me a MAF from courtesy because of the stalling out...should arrive wednesday...we'll see if this fixes me up.
Old Oct 4, 2008 | 08:42 AM
  #44
villalobos's Avatar
Friends ... My MAF crapped out also, unable to rev past 2500rpm... Code 0113 along 0101 0102 pointed to low and high output from the MAF sensor.
Checked out the resistance of the sensor itself and it checked out ok. (2.1k kh at room temperature) Now I', stumped.. Checked out vacuum lines and everything looks fine. I do have a Apexi filter Intake system but I've had it for 70k miles and never had a problem.. I alos have two faulty O2 sensors....Not sure if the sensors are helping the bad MAF reading....I plan to start checking voltages on ECM side to see and see if things check out... Any thoughts???
Old Oct 8, 2008 | 01:51 PM
  #45
Crasher's Avatar
Be sure all of you replacing those MAF sensors are not running a K&N air filter. The oil deposits on those things are known to mess with those sensors.
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
