Customizing Big Brakes
Old Sep 28, 2005 | 11:59 PM
A33 VQ30DEK's Avatar
Would this ever work?
My friend has a 240sx and he's using jeff's bracket, cobra rotors, 3z caliper etc and I was thinking since our kit works with his car, would it be possible to get one of the 240sx big brake kits to fit our cars. Like stoptech or Project Mu or is there something that i'm missing from here. Could it be possible that we could fit there aftermarket big brake kits onto the maxima.
Old Sep 29, 2005 | 12:42 AM
LithiuMax
How are you liking your lights?
Old Sep 29, 2005 | 09:58 AM
its great... but that doesn't answer my question?
anyone? Matt, jeff, Larry..?
Old Sep 29, 2005 | 10:00 AM
OOmaxSE's Avatar
i thought 240sx were 4-lug?
Old Sep 29, 2005 | 10:15 AM
not all. I believe some of the s14s have 5 lug. They can also do a 5 lug conversion also.
Old Sep 29, 2005 | 10:21 AM
OOmaxSE's Avatar
are you trying to change up your bbk? how's the braking on your set up btw?
Old Sep 29, 2005 | 10:29 AM
Jeff92se's Avatar
I'm needing a caw
I don't know how your friend is using my brackets. RWD and FWD Nissans have different dimensions. Either the pad overhang is going to be excessive or the rotor will be scraping the caliper. I don't remember which. Did he buy the brackets from me? I don't remember anyone with a 240 inquiring about them.
Old Sep 29, 2005 | 10:41 AM
matthel bought them off of you... and he bought them off matthel.
The caliper doesn't bite much of the rotor as the maxima does.
heres a picture.
Old Sep 29, 2005 | 10:43 AM
Jeff92se's Avatar
I'm needing a caw
Thanks for the info. Yup. There is a dimensional difference. Probably in the 3-4 mm range of more pad overhang.
And to answer your question, you can get those other kits. But they won't fit properly. But there are already 3-5 kits available for the maxima so I don't quite understand why you would want these other kits. And since the 240 weighs diff, kits for those might not be sized properly vs the current selection from StopTech, Stillen, Blemco, etc............
Old Sep 29, 2005 | 10:44 AM
thats the only picture i have of his car. I'll try to get more later.
So it would work huh?
Old Sep 29, 2005 | 11:02 AM
Jeff92se's Avatar
I'm needing a caw
"works" is a relative word. But put it this way. If I didn't think the dimensional differences weren't significant, I wouldn't have spent the time, money and trouble developing my own brackets for the maxima application.
Old Sep 29, 2005 | 12:46 PM
ok ok i see where you're heading to.
Old Sep 29, 2005 | 03:54 PM
vsamoylov
hey jeff check your pm.
by the way a33 vq30dek, you said "The caliper doesn't bite much of the rotor as the maxima does". re you talking about your bbk? you see i bought jeffs brackets but i am trying to figure out if they will work with the 13 inch cobra rotors on my 2k2 max.
Old Sep 29, 2005 | 08:06 PM
Larrio's Avatar
The Definitive AE Master
yea... what jeff said, brian.
The hubs are relatively the same, hence the 300zx caliper bolts up to the maxima and the rotor doesn't have any offset issues. However in the case of BBK's, the bracket design gets more complicated as there are clearance issues and stuff between the front hub area in a fwd and rwd application. Oh.. this is IMO
Old Sep 30, 2005 | 02:01 AM
this sucks. I wish project mu would make some bbk for the a33.
Old Sep 30, 2005 | 07:46 AM
Larrio's Avatar
It would just mean harder to find and more expensive parts
Project mu already makes brake pads for the cefiro, you could try them out. If you really wanted you could purchase the 240sx project mu bbk and see how fitment is with the maxima and then slightly change the bracket design to work. The AP bbk fitment is already super close (w/in a few mm) in the tight clearance area of our front hubs
Old Oct 3, 2005 | 08:59 AM
Jeff92se's Avatar
I'm needing a caw
Why? You already have more braking force than God himself? You want to complete this great bbk? Buy Matt's rear bbk. Put that on and you won't believe what this does to your braking. I run a front/rear bbk (diff rear kit than Matt's - won't fit a 4 gen) and the braking is nothing short of incredible.
Old Oct 5, 2005 | 01:45 AM
wcasskicker's Avatar
If upgrding to BBK, are we required to change the master cylinder?
Old Oct 5, 2005 | 07:50 AM
Nismonkey's Avatar
Why not just go with a big brake kit from BREMBO or STILLEN? I guess my reply would be the $$$ issue.
Old Oct 5, 2005 | 08:45 AM
Jeff92se's Avatar
I'm needing a caw
It's only money right? Like $1,000+ money difference.
Old Oct 5, 2005 | 09:45 AM
mingo's Avatar
if the piston bore area in the new caliper is way bigger than yes. but for most set ups that are available, no
Old Oct 5, 2005 | 11:52 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
You know what you need, Brian? These...
http://forums.maxima.org/showthread.php?p=4278417
Old Oct 5, 2005 | 01:06 PM
chinaonnitrous1's Avatar
if you sell theos at the price of a 300zx bBK upgrade...i'll take them!
even though i dont have a maxima anymore.
I'll use it as a wall clock.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
