Stock Struts worn out, what to replace them with?
Old Sep 29, 2005 | 09:25 PM
Stereodude's Avatar
My Max has about 75k on it, and I think the struts are pretty well worn out, so I'm looking to replace them. I see there are choices from Tokico, KYB, all the way to Monroe Sensa-Trac's.
What struts are on the car stock?
What aftermarket strut is closest to the factory ride? I'm not planning on lowering the car or messing with the springs, so that's not a consideration.
Old Sep 29, 2005 | 10:09 PM
Puppetmaster's Avatar
Tokico HPs or AGX GR-2s.
http://www.innerbean.com/housecor/sp..._decision.html
Old Sep 29, 2005 | 11:55 PM
lowincash's Avatar
No More Maxipad
i had over 80k and i just had stock shocks replace with tokico hps and the ride was a lot smoother. i'm on stock springs and before i replaced them i would feel every bump on the road now the ride is much smoother. it's good price for the hps instead of getting them from dealer which costs over 200 each i believe.
Old Sep 30, 2005 | 03:43 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
if you want to adjust your ride get the Illuminas... they will cost around 100.00 more than the HPs...and about lowering.. think about it again. I did and trust me the car look much better... and I was in the same boat. Maxspeeds and Illuminas......
Old Sep 30, 2005 | 04:55 AM
maximo-SE's Avatar
i heard maxspeeds and illuminas provide the best ride in comfort and performance.... anyone confirm? I think housecor said something about that but im too lazy to click on the link.....
Old Sep 30, 2005 | 05:59 AM
soundmike's Avatar
Very sound, Mike
GR-2's are said to have a 2/3 setting on the Illumina's. (Which is about 10-15% stiffer than OEM) That said, a lot of people on Illumina's are using that setting on Maxspeeds and other springs.
With that in mind, if you don't plan on adjusting a lot - the GR-2's are probably your best (and most economical) choice.
Take into account, that though the Illumina's are adjustable - that function is there to help you tune the struts to your springs rate. Granted, you can go softer or stiffer than the optimal setting, but how many times will you be adjusting?
Some things to think about.
Old Sep 30, 2005 | 11:47 AM
Well put, and I also wanted to add this:
Originally Posted by njmaxseltd
True, but Tokico's valving is different then KYB's valving. Tokico tends to allow for a bit less rebound dampening, while KYB is just as firm on the compression stroke as on the rebound stroke. I feel thats what gives Tokico struts a better ride then KYB.
On the other hand Koni Yellows, which are also adjustable, only adjust rebound dampening, the compression dampening is fixed.
If you think about what the differance is you get a sense of how all the struts differ in ride. Koni valving gives you more of a planted down on the road feel, while Tokico gives a more like being on top of the road feel. Both have their pro's and con's. KYB simply dampens firmly in both directions, pretty basic ride control technology. Koni shocks are known for their excellent handling, (planted on the road) while Tokico I feel is known to provide a better ride while providing excellent handling as well. KYB's just ride very firm, which in turn gives you great handling. Koni's would be the choice for guys that auto-x their cars while Tokico is better for a daily driver just looking for added control while maintaining a nice ride.
If you play with an OEM Nissan strut from a Maxima, you'll find it has moderate compression dampening and fairly firm (slow) rebound dampening. That sort of puts it in a class by itself, then again they are tuned for the stock springs in our cars.
Old Sep 30, 2005 | 12:58 PM
00SEMAX19's Avatar
http://forums.maxima.org/showthread.php?t=281189
Old Sep 30, 2005 | 04:04 PM
Stereodude's Avatar
Originally Posted by 00SEMAX19
I looked through that thread, but most of the people posting seemed to be running non OEM springs.
Old Sep 30, 2005 | 04:51 PM
lowincash's Avatar
No More Maxipad
since you wanna keep stock springs and want soft ride i think the tokico blues will be good since i read that the gr2's are slightly stiffer than the blues. for me they seem to get smoother each day than when i first got them installed...are the shocks being worn in right now?
Old Oct 1, 2005 | 04:35 PM
Guru's Avatar
I'm using Tein Hi Tech's and have a set of Tokico Blues here for them. The ride is terrible with the blown rear shocks. For the money the Tokico Blue's are an excellent choice.
Old Oct 1, 2005 | 07:25 PM
Wiredmax's Avatar
I have the tokico illuminas and the H&R Spring setup in my 03 max, i got no complaints about them, i rarely have to adjust them though, i always leave them on the 3rd setting, i would definetly recommed them for the money.
Old Oct 2, 2005 | 07:00 PM
maxima_million's Avatar
Is it me??? I brought my car in to get the 02 sensors replaced and asked them to look at the front shocks/struts. They came back and said that if the ride is ok, then don't mess with them. I figured - ok - honest mechanic!
That was 1 week ago. Just this morning, I went to step on the brakes and I hear a 'thump thump thump...'. At first, It freaked me out because I found myself in the center of Newark, NJ (not a great area).
Could it be the struts? I mean - the timing is ironic!
Thanks!
Old Oct 2, 2005 | 09:33 PM
mustang-gt's Avatar
hi im a newby here, i own a 2002 se auto and i run 14.4 1/4mile stock
are there any free mods I can do to get a little more power.
Old Oct 3, 2005 | 04:30 AM
BlackIcemax's Avatar
Thanks!
try all brands nissan in hackensack they fixed my car before ask for glen
Old Oct 3, 2005 | 04:54 AM
nicks79's Avatar
One mode would be to open the window so that all smoke leaves the car, cause your definetely on drugs..
Old Oct 3, 2005 | 07:37 AM
boondoxmax's Avatar
Tokico HP all the way. smooth as glass!!!!!!!!
Old Oct 3, 2005 | 04:58 PM
cabernet's Avatar
Has anyone seen a better price for the Tokico HP than $309 shipped on ebay?
Old Oct 3, 2005 | 05:03 PM
lowincash's Avatar
No More Maxipad
i got mine for $400 installed for all four. the labor price is $120 so i think i got mine for $280 or so.
Old Oct 3, 2005 | 05:06 PM
cabernet's Avatar
Thanks. Was that a chain store that sold and installed them or a local shop?
Old Oct 3, 2005 | 05:11 PM
lowincash's Avatar
No More Maxipad
not really they're just some local shop i always go to. i just called them and the price for the shocks were $300 and install was $100 my bad
Matt93SE
May 24, 2019 02:58 PM
melteye
May 16, 2016 12:02 AM
jhontelj
Aug 17, 2015 04:07 AM
District
Aug 15, 2015 08:23 PM
