anyone with a greddy emanage ultimate?
Old Oct 4, 2005 | 04:25 AM
mingo's Avatar
i was stuck on the pinout and i was hoping that those of you that already have it can help me out with this.. so far this is what i've found, i'm not sure if it's correct though..
alright, i looked up all the wires on the FSM and i want to compare notes
here is what i got, please correct me if i am wrong
this is for a 2000 maxima.
injector 1 = terminal 101
injector 2 = terminal 103
injector 3 = terminal 105
injector 4 = terminal 107
injector 5 = terminal 102
injector 6 = terminal 104
ignition signal 1 = terminal 21
ignition signal 2 = terminal 22
ignition signal 3 = terminal 23
ignition signal 4 = terminal 30
ignition signal 5 = terminal 31
ignition signal 6 = terminal 32
rpm= 25
vias=16
ground=58
MAF= 61
coolant temp= 70
intake air temp= 64
vehicle speed= 86
throttle position= 91
crank (pos)= 85
crank (ref)65, 75
cam (phase)= 66, 76
knock= 93
one wire i can't find is the 12v source. could it be 67?
Alex, care to correct me? because so far i think you're the only 5th gen that has this thing hooked up.
i'm not sure what to set my vehicle code to. so i'm going with vq30det. and i'm not sure how to set the knock feature.. can the EU retard timing when it see's knock like the j&s?
thanks in advance
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
