will 4th gen and 5th gen coiover swap over
Old Oct 5, 2005 | 11:58 AM
NismoGTR's Avatar
can a 4th gen coilover kit fit the 02 maxima....vise versa......interchange basiclly
Old Oct 5, 2005 | 12:04 PM
Puppetmaster's Avatar
I think the rears are different....
Old Oct 5, 2005 | 01:50 PM
RA030726's Avatar
I'm nutty for Nissans
the front lower bolts on the strut are not the same.
Old Oct 5, 2005 | 01:53 PM
Okay... guess its the front..
Old Oct 5, 2005 | 01:56 PM
steven88's Avatar
Need A Light?
So the rears bolt on with no modification? I've seen both gen4 and gen5 rear springs+struts...they look very similiar...always wondered if they are interchangeable
Old Oct 5, 2005 | 03:07 PM
00SEMAX19's Avatar
Somebody on here installed 4th gen coilovers on a 5th gen and I'm sure that they only had to slightly modify the rears
Old Oct 5, 2005 | 04:23 PM
RA030726's Avatar
oh oh i forgot the rears have larger upper mounts. hehe so nope its a no go.
Old Oct 5, 2005 | 05:49 PM
BEJAY1's Avatar
Conecarver
By drilling out oval holes "I believe" you can interchange that or somebody here did already. This is a great topic as it would allow for Tein's EDFC to work on a 4th gen . I should've gone that route 2 years ago but oh well...
Old Oct 5, 2005 | 06:11 PM
RA030726's Avatar
well the bolt pattern is off quite abit. this is a 5th gen mount on a 4th gen.
it would take some modifying but sure it could work. you could then swap steering knuckles to run the appropriate front struts.
Old Oct 5, 2005 | 06:33 PM
mtrai760's Avatar
'Trynna' is not a word
What's with that strut bar? I hope your not running it like that
Old Oct 5, 2005 | 06:35 PM
I think he was just using that to illustrate the different bolt pattern. More concerning is how the orange plastic gasket is all chewed up on the inside.
Old Oct 5, 2005 | 06:51 PM
RA030726's Avatar
dont worry about the bar... i have been running it for a while now. its secured a lil different tho. the orange is the stock gasket. they always tare up like that, but i installed a better one.
Old Oct 5, 2005 | 10:24 PM
mtrai760's Avatar
Those orange gaskets dry out and shrink, its normal. Only having one bolt holding the strut bar, with the other nut only half holding the plate is not the safest idea though. As that bar/plate flexes, it will have a natural tendancy to loosen that nut. Watch out is all I'm saying....
Old Oct 6, 2005 | 01:02 PM
NismoGTR's Avatar
i got a 4th gen and just bought a 5th.....so i want to swap my tein basic damper coilover to the 5th
Old Oct 6, 2005 | 02:16 PM
Kevlo911's Avatar
Kevlo for President
I have read that the front lower strut mount is WIDER on the 5th gens. But you CAN use the 4th gen springs on the front. As for the rear, I believe the bottom part is the same and it is just the upper mount that is different.
MAXSE5SPD
Sep 17, 2022 04:00 AM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
