Headlight adjustment
Old Oct 9, 2005 | 01:48 PM
2000blkse's Avatar
I installed my HID’s Friday night. They look great but the beam pattern is off on one side. Im using the helios hids with the stock 2000 capsules. I know it’s not the Hid’s because it was doing it with the old PIAA bulbs. It’s just more noticeable now because they are brighter. Im trying to get my camera back from my buddy so I can post some pics, but has anyone else had this happen… the beam pattern is normal until you get to the far right side _____/ and it jumps up at about a 45 degree angle.
Basically is there anyway to adjust the headlight any other ways except for the white ***** on the back of the headlight? Ill try to post some pics later.
Old Oct 9, 2005 | 02:03 PM
SixxOne's Avatar
my projectors have the same thing. Its supposed to be like that
Old Oct 9, 2005 | 03:22 PM
SHouKan's Avatar
yup.. my PIAAs and my Helio HID 5000K do that.... hows ur glare with the HID?... are you using stock housing
Old Oct 9, 2005 | 03:41 PM
2000blkse's Avatar
That is really weird why it does that. Its like my headlight is winking... I don’t think there is a glare or if there is its not alot I parked in a parking lot and walked around to get different views and it looks great. Also no one has flashed me yet. Yes I am using the stock housing. How do you like the 5000K? I decided on the 6000K for the headlights and fogs…
Old Oct 9, 2005 | 08:00 PM
Sam524's Avatar
is there a way you can tilt up the headlights? my hids are strong, but most of the time i have to use my high beams because they dont go out far enough
Old Oct 9, 2005 | 09:27 PM
OHH NOES's Avatar
6spd Swapped
The white ***** on the back of the headlight adjusts the beam up and down, try that
Old Oct 9, 2005 | 11:26 PM
SHouKan's Avatar
the HID 5000K is good.... really really white.... no hint of blue at all. I was debating between the 5000 and 6000 but i figure i'd go for the 5000 for the better visibility but i doubt there is even a difference. I must say though... I drove it for about 2 weeks now, I did get flashed one time... but that was it.... I don't think the glare is bad at all. I drove behind my friends STI and accord and I asked if I was blinding them. They said it was fine and not blinding at all.
Old Oct 10, 2005 | 04:02 PM
ope2k4's Avatar
STI and new gen Accord both have one thing in common. They both have higher or elevated trunk style just like 5th gen maximas. You should try parking about 8 feet from a regular yellow cab then adjust your white ***** until the beam is at or below the top of the trunk. Notice the driver side head light will always be lower than the right one.
As for the reason why the passanger headlight is higher than the driver's side, its because of the oncoming traffic.
Belive me I had the same problem before (mine is still a little glary this is because I have D2R HID bulbs in my 00 factory headlight)
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
