bad engine mounts?
Old Oct 12, 2005 | 04:38 PM
gameover03's Avatar
bad engine mounts?
ok guys lately i have been hearing a clunking sound coming from the passenger side of the car when i go over bumps...i thought it was my coilovers but..today after i started the car in a stationary position the same clunking sound came..what are the symptoms of bad engine mounts? or is it a bushing from my suspension or something? ne input will be greatly appreciated..?by the way i have 128k on my car....
Old Oct 12, 2005 | 04:56 PM
Derrick2k2SE's Avatar
You'll hear the bad mount when you get on and off the gas while moving. If you are in a lower gear it will be more pronounced. Put it in a gear that puts you a around 3500 to 4000 RPM at around 20 to 40 MPH. Get on and off the gas a few times and you'll hear the mount banging each time.
If it does turn out to be a bad mount the Energy Suspension mounts from Cattman are a great upgrade. They really help with wheel hop and make for crisper shifts. Pretty easy install too.
Old Oct 12, 2005 | 06:03 PM
gameover03's Avatar
well while the car was cold after starting it up it did the same sound between 1k-3k...
Old Oct 12, 2005 | 06:46 PM
wanta02max's Avatar
how much do those things go for? I think I've got a bad mount as well....any write-ups on the install?
Old Oct 12, 2005 | 07:49 PM
BewstAdd1ct's Avatar
yea, how much are the cattman inserts? i saw them on a site for $80, wasnt cattman, tho
Old Oct 12, 2005 | 08:17 PM
rbrown81's Avatar
But why is teh Rum gone?
How tough is that install? Id like to get a set.
Old Oct 12, 2005 | 09:06 PM
Yeah, it'll do it at any RPM. There's just more torque to move it around in the higher RPM range. I don't know why it would only happen when cold. You can inspect them from under the car. It should be obvious if one is bad. I think the one closest to the firewall usually goes first.
The install on the motor mounts isn't hard. THere's a support beam under the motor held on by 4 bolts. It's held onto the motor by 2 bolts that go through the motor mounts. You basicaly remove the beam with the mounts and have them pressed out at a shop. Have them press the new ones in. It's a simple job, there might be a write up but they come with directions. If you've ever done any suspension work or even brakes you should be able to handle it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
Apr 8, 2018 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
laparka66
Aug 6, 2015 09:36 AM
