Car Problem - Thunking Noise in Reverse
Old Oct 18, 2005 | 02:21 PM
bgates1654's Avatar
Whenever I put the car in reverse, give it some gas and let out the clutch the car lurches and makes a clunking noise. After that everything is okay. When I put it in gear (manual) and drive forward nothing happens, unless directly after the clunk in reverse. In that instance I get the clunk again when giving it gas and releasing the clutch. Any idea what this could be? I took it to the dealership, but they said they could not reproduce it. Frankly I dont think the guy was listening to me when I told him the problem becuase it said on the work order that it was a clunking sound going over bumps. I have no idea how he got that out of what I said. What do you guys think? CV join maybe?
Old Oct 20, 2005 | 09:28 AM
bgates1654's Avatar
bump......
Old Oct 20, 2005 | 11:53 AM
Jay_pee99's Avatar
Possibly a motor mount!
Old Oct 20, 2005 | 08:21 PM
BewstAdd1ct's Avatar
+1 for motor mounts...
Old Oct 20, 2005 | 08:32 PM
white m3 guy's Avatar
possibly your wheel bearing
Old Oct 21, 2005 | 09:11 AM
bgates1654's Avatar
I would have went for motor mounts too but I just replaced the stock one with the ES mounts not too long ago. On top of that if it were the motor mounts the motor would slop every time I got on or off the gas hard which it doesnt.
I will check into the symptoms of a wheel bearing issue. Thanks guys.
Old Oct 22, 2005 | 01:49 PM
zoner's Avatar
Another thought - could be your brake pads shifting...
Good luck!
Old Oct 23, 2005 | 07:46 PM
Ephraim's Avatar
so you have a 5speed? if so then it is probably one or both of your rear brake calipers sticking. it happens to me, and i need to get my rear drivers side caliper rebuilt or replaced. there is a rebuilt kit at autozone or whatever car parts store you frequent.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kirkhilles
Aug 8, 2015 10:53 AM
