Yes another MAF question But could someone Help confirm my problem!
Old Oct 19, 2005 | 11:27 AM
Maximized2000's Avatar
HEy guys,
My car has been sluggish for the past couple of weeks. The simptoms got worst yesterday because when I was crusing on the highway at 60mph and wanted to go 75mph I stomped on the gas pedal (auto) and my RPMs would not jump over 3000 RPM. At 60 MPH it was at 2500rpm and when I stomped on it it would slowly and I mean slowly climb up to 3000 RPMs and thats it.
I searched this site for answers and from the symtoms I believe something is probably wrong with my MAF. However, the SES light is not on.
SO could someone help confirm that it is my MAF before I bring it to my local repair shop.
Thanks!
Old Oct 19, 2005 | 11:49 AM
Stardust's Avatar
F---ing Kangaroos
It's most likely the MAF, but don't take the car to a repair shop. Give Dave Burnette a call to order one. If you can turn a screw driver you can install it yourself.
Old Oct 19, 2005 | 11:55 AM
Yeah but thats why I want someone to confirm it first before I order the part. I don't want to be stuck with the part like someone I read on the org. Someone on the org. purchased a new maf too see if that was the problem and it ended up not being the problem nd he sold it in the classified section.
Isn't there a way that a repair shop can check to see if the Maf is bad?
Old Oct 19, 2005 | 12:33 PM
Stardust's Avatar
F---ing Kangaroos
Not really.
Old Oct 19, 2005 | 12:43 PM
2002 Maxima SE's Avatar
Try cleaning it first. If you still have problems, order a new one from DaveB.
Old Oct 19, 2005 | 03:15 PM
What is Dave B's number or his Org. name? Do we get discounts from ordering it from him?
Old Oct 19, 2005 | 03:31 PM
oh, I forgot to mention that when I have the car in park and I rev the engine the needle does jump past 3000 RPM without a problem. But when I rev the engine when I am going 60MPH it doesn't rev past 3000RPM. Is this weird?
Old Oct 19, 2005 | 03:53 PM
OOmaxSE's Avatar
i'm interested... how do you clean it?
my car yesterday BOBBLE through the RPMS and i couldn't even drive... had to pull over and check it. i ended up unplugging the batt and MAF for 15 mins and it was fine. felt like a horrible wheel bearing that's been driven on for 2 years!
Old Oct 19, 2005 | 06:01 PM
These MAFs can be cleaned. A lot of folks go out and drop $100 because the MAF "blew". I laugh.
Take a Q-tip and some isopropyl alcohol or electric parts cleaner. Remove the MAF from the intake with the star security tool. Gently wipe the filament looking piece (see all the dirt/grease on your Q-tip). Allow to dry and replace. It's that simple and may save you some dough.
I found this from 2002 Maxima SE's previous replies to another thread. Some say it doesn't work and some say it does. I will probably wait until my Maf is really gone before I buy a new one.
Old Oct 19, 2005 | 06:04 PM
OOmaxSE's Avatar
nice, i do'nt have the star security tool so i guess i'll have to take the whole assembly apart, 'eh?
Old Oct 19, 2005 | 07:08 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
This should be made a sticky--
Put some Cascade or Palmolive oil in your dishwasher and put the MAF in there for bout 30 min, throughtly clean the MAF. After that put it in the a preheated oven for 20 min at 475F to dry it off. Works every time.
Seriously do we need 100000 MAF threads on this forum ? Read the dayamn stickies !
Old Oct 19, 2005 | 07:11 PM
Stardust's Avatar
F---ing Kangaroos
Old Oct 19, 2005 | 07:24 PM
Puppetmaster's Avatar
I think it was 450, Mike... and my toaster oven worked just fine....
Old Oct 19, 2005 | 07:30 PM
Stardust's Avatar
F---ing Kangaroos
I'm going to try the microwave. I'm sure I can cut the time in half.
Old Oct 20, 2005 | 04:22 AM
You can use throttle body cleaner or rubbing alcohol and a Q-tip. Just be very gentle with it.
Old Oct 20, 2005 | 04:23 AM
Old Oct 20, 2005 | 04:25 AM
You can buy it at any automotive store. You will need it to clean the MAF, otherwise it will be tough to reach it.
Old Oct 20, 2005 | 09:29 AM
StillenMax80x20's Avatar
yeah, sure, that'll do it, i think...
blackbirdvq
a dishwasher huh? i have yet to hear of that, but i've cleaned 2 car's mafs' w/ tb cleaner and isopropyl and no probs. but a dishwasher and an oven.... wow, no melting plastic or wire insulator? i have taken the security screws off and actually re-sauldered an old maf to REALLY bring one back to life!!
Old Oct 20, 2005 | 10:57 AM
Derrick2k2SE's Avatar
Try to find someone with the same car and swap sensors. It's an easy job and "non invasive" to either car. You should know right away if it's the MAF or not.
Old Oct 20, 2005 | 02:22 PM
blackbirdvq
Well I use my fiancee as a dishwasher (wife will do just fine in this application), so I really wouldnt know how good a Maytag would clean the MAF out. In order to get the MAF dry again you can put it on a cooking tray- make sure to spray it down with PAM (non stick spray) and put it in the oven. I don't recomend microwave as the MAF has some metal parts inside that will spark.
BTW how did you solder the MAF togheter ? There really is no room to solder it as the Hot wire element isn't exposed enough, unless you got a microscopic solder then good for you.
Old Oct 20, 2005 | 06:44 PM
venom32225's Avatar
Damn that was funny!!
Old Oct 20, 2005 | 06:55 PM
ope2k4's Avatar
HEy guys,
Thanks!
HM you might wanna make sure your fuel pump is still supplying enough gas and It might just be a combination of both the fuel pump and MAF because low fuel supply and bad MAF makes a SLOW maxima
cruce91
Sep 20, 2015 10:23 AM
fulloboost
Sep 12, 2015 08:03 AM
Slamrod
Sep 3, 2015 07:38 PM
95Maxi
Aug 29, 2015 09:38 PM
Samedi
Aug 13, 2015 04:05 PM
