Throttlebody Cleaning instructions
Old Oct 19, 2005 | 12:41 PM
Compton's Avatar
Are these the instructions for the 4th gen or 5th gen? (or both)?
If not 5th gen, does anyone have a write up of this?
http://www.motorvate.ca/mvp.php/518
Old Oct 19, 2005 | 12:45 PM
UGAd13's Avatar
I'm pretty sure it will work for both 4th and 5th. But don't do that if you have a 5.5gen. It will F up your TB. Luckily I didnt have to replace mine, but others have had to.
Old Oct 19, 2005 | 01:12 PM
Compton's Avatar
ok thanks. I have a 2000 max. thought id clean the tb when i replace MAF 2nite.
Old Oct 19, 2005 | 01:27 PM
steven88's Avatar
Need A Light?
yeah its easy for a 2000...just pull the butterfly plate open and start spraying with TB cleaner....get a rag and wipe until rag is clean....then enjoy smoother idles!
Old Oct 19, 2005 | 04:45 PM
bladerunr's Avatar
What's this about hurting your throttle body in a 5.5 gen? Why can't we spray cleaner in there and wipe it out? Please explain.
Old Oct 19, 2005 | 08:40 PM
99 SE-L
We have Electronically controlled throttle by wire, and the buttery fly realigns it self, if you attempt to clean it you will damage the TB.
Old Oct 19, 2005 | 08:44 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
So we 5th genners can clean the TB without fear of fawking something up? (assuming sound mechanical aptitude is in line, of course...)
Old Oct 19, 2005 | 09:04 PM
BigFly_2K2SE's Avatar
I just wanted to comment that I have a 2K2 and I cleaned my TB quite some time ago before all of the horror stories got posted on the ORG and all worked out okay for me. I got a CEL right after I finished but I think this is because I unplugged the MAF without disconnecting the battery. I reset the ECU and the CEL never came back. I also had a high idle for a while but the throttle position learning procedure or whatever it's called fixed that and it has been fine ever since.
I am not saying it is a good idea and I am not sure I would do it again, but to say that "cleaning your TB in a 5.5 gen will wreck it" is not correct.
Old Oct 19, 2005 | 09:37 PM
MaximaPolak's Avatar
Step one: Don't do it...too many people had problems after they cleaned their TBs.
Step two: Wash your car.
Old Oct 19, 2005 | 10:39 PM
steven88's Avatar
Need A Light?
Be very cautious when cleaning the 5.5 gen throttle body...or better yet, just don't attempt at all....theres too many people in the 5th gen forums with messed up TBs after cleaning it up...
I personally have been a lucky guy to not break my TB....but my procedure was kinda different from others...I took apart the whole IM (including the TB still connected) off the whole engine...then very gently press against the butterfly plate slightly open...then start spraying the **** out of it....the liquid will flow out of the IM runners so have a rag under it to catch the fluid....it worked great and no SES or high idle...but I'm not sure if I am gutsy to try it again
Old Oct 20, 2005 | 05:55 AM
UGAd13's Avatar
You are correct. However, if you follow the procedure outlined on that website you have a greater chance of damaging the TB than if you were to remove the TB and clean it that way. Manually moving the butterfly value while cleaning our (5.5gen) TBs is where people run into problems. Luckily, after I did that I was able to reset my CEL with no futher problems.
Old Oct 20, 2005 | 08:51 AM
bladerunr's Avatar
OK. So it's not the cleaning fluid that damages the TB, it's moving it manually. Got it. They should put that in the damm owners manual.
Old Oct 20, 2005 | 09:13 AM
I actually started the procedure by manually moving the butterfly valve, but I didn't think that "felt" right, so I finished by turning the key to the car on and propping the gas pedal to the floor to keep it fully open. I am not sure if this is a good idea or not but it is what I did.
Old Oct 20, 2005 | 08:08 PM
BewstAdd1ct's Avatar
ive cleaned SEVERAL e-throttle bodies without problem, moving them by hand.
i think its a KAM issue and PROPERLY running the idle learn.
Old Oct 20, 2005 | 08:42 PM
MadMaxNH's Avatar
Fortuna Favet Fortibus
I just had the dealer do a TB cleaning on my 5.5 and I got a SES light the next morning. There is actually a TSB that says if you have a idle that is faster than 25 rpms of what it should be after it is warmed up after you clean the TB on the 02-03's you have to check the ECU program and reset the IVAL with the consult. This will make it idle right. Mine was actually retarding my timing down to 12. I would think reseting the ecu with the pedal thing might work too but that is the cause.
Old Oct 20, 2005 | 09:28 PM
reset KAM and run the full learn. all 3 procedures.
Old Oct 21, 2005 | 05:31 AM
Blu's Avatar
Blu
the tits
do it and be prepared to gain 50whp, I cleaned mine and was like Whoa!
Old Oct 21, 2005 | 10:43 PM
MadMaxNH's Avatar
Yeah it definitely feels perkier. I run Toyos and I usually can only get them to break loose briefly from 1 to 2 and yesterday I rolled them good on the same shift. Typically those tires really grab quickly. Good thing to do while it is in for service for the extra 150 bucks. I am pleased.
Old Oct 23, 2005 | 04:03 PM
Compton's Avatar
UPDATE:
I replaced the MAF unit/sensor, air filter, PCV valve and cleaned the throttlebody while I was at it without any problems (or CEL)
Total cost : About $100
Thanks for the help everyone
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
