slippage between 4th and 5th gear (manual tranny)
Old Oct 20, 2005 | 09:14 AM
ms.thicknes's Avatar
hey all
are any of you manual tranny's having an issue where if you are "riding out" in 4th gear and the stick just slips out of gear and the transmission also has slipped so when you press the gas all the engine does is rev and not accelerate?
it does it in 5th gear too
off course the dealer "cannot replicate the issue" as usual
they suck so majorly its not even funny
Old Oct 20, 2005 | 05:40 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
check for broken engine mounts 1st, if that doesn't look damaged or worn out- your trans needs a rebuild. Shift forks and baulk rings need repleacement- I would also do 4th and 5th gears with syncros.
Old Oct 20, 2005 | 09:19 PM
BewstAdd1ct's Avatar
if they cant duplicate it, you need to go for a ride with them. show them the problem. its that easy.
make sure your hand isnt on the shifter when its happening. i might be leaning toward a bent fork... whats the year/model?
how many miles on the car?
Old Oct 21, 2005 | 01:29 PM
It happens whether my hand is on the shifter or not! lol
2k1/68K
Old Oct 22, 2005 | 02:19 PM
id lean toward bent fork/weak detent. only 4th and 5th are different forks and use different detents.
ck the motor mounts, like bbird said, but i think the jump-out would be more pronounced in 1st and 2nd if that were the case
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
