Sunroof Button
Sunroof Button
the sunroof switch on my 2000 GLE works but it stops every two seconds. the sunroof opens all the way but I have to keep releasing and re-applying regular pressure on the switch. what kind of problem do you think i have??? I would think it is a bad switch, but I was wondering if anyone has had the same problem. so any input would help.
I could not find it in the how to fix area. I not sure on how to recalibrate the sunroof either. Like I said it opens all the way but I have to continuously push - let go - puch - let go. it is annoying. I imagine that it could be just the switch that has gone bad, but I dont wnat to go buy a switch then that not be the problem.
If you want to perform the sunroof reset here it is:
• If the sunroof is open, press the tilting switch repeatedly toward tilt "Down" to fully close the sunroof.
• After the sunroof has closed all the way, keep pressing the tilting switch towards tilt "Down" for more then three seconds.
Thats exactly as it reads from a sunroof TSB. See if that fixes your problem.
No luck the TSB recomendation did not work, or I did not do it right. anyone else have any other recomendations??? I just noticed that the tilt button will also open and close the sunroof in the same way that the other "slide" button does.... weird???
tarun900
19
Dec 20, 2021 06:57 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
