front speakers
Old Oct 31, 2005 | 10:21 AM
BioMaxDDS's Avatar
front speakers
any1 have instructions on how to remove the front door panel to get to the speakers?
search function isn't working
thanks
Old Oct 31, 2005 | 11:15 AM
SixxOne's Avatar
http://forum.maxima.org/search.php?searchid=328862
Old Nov 1, 2005 | 02:54 PM
BioMaxDDS's Avatar
Sorry - no matches. Please try some different terms.
Old Nov 1, 2005 | 03:17 PM
filtor1's Avatar
This would fit right in the AUDIO forum.
#1 Remove trim around door handle.
#2 Remove single screw(hidden in black pocket) that has a small round cover easily removed with a flathead. Pull that pocket out after removing screw.
#3 Remove single screw located in the front of the panel (covered by a, pick your interior color, cover) also easily removed with a flathead or fingernail.
#4 Place a finger in the small slot located at the bottom of the door panel and pull tward you. After releasing all of the retainers, lift up to slide the entire panel off the door.
#5 Disconnect 3 harnesses. 1 for the door light(bottom). 2 window switches(center). 3 lock & unlock(also center)
To remove the speaker you will need a phillips screw driver. If you are replacing the factory speakers, the process is identical on the other doors.
wyobbagy
Jan 3, 2023 12:03 PM
9aj9
Apr 5, 2020 12:11 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
