High Idle..
Old Oct 22, 2005 | 03:51 PM
99 SE-L
High Idle..
Hey guys i recently installed my stock intake back in and noticed an abnormal Idle what can this be from?
Old Oct 22, 2005 | 03:54 PM
Shogunsc4's Avatar
have "idle air volume learn" performed...if it doesnt help..its a bad ECU. It happened to my 2k3 after the dealer replaced a TB.
Old Oct 22, 2005 | 03:59 PM
99 SE-L
I think a dealer would charge an Arm and a leg for this....
Old Oct 22, 2005 | 04:05 PM
Shogunsc4's Avatar
Idle Air Volume Learn:
http://www.technosquareinc.com/350reset.htm
As for replacing the ECU...it's under the emission warantee 8/80. Just make sure you take out any mods you have in the engine bay
Old Oct 22, 2005 | 04:09 PM
99 SE-L
My warranty is gone car currently has 93k on it
Old Oct 22, 2005 | 04:14 PM
Shogunsc4's Avatar
the dealer will probably charge somewhere around $700-$800 for the 2k2 ECU. You can always go the cheaper route and get the ECU from car-parts.com and DIY. Or order it from DaveB and DIY. Good luck
Old Oct 22, 2005 | 04:17 PM
99 SE-L
Iam just going to let the ECU adjust to the intake, then well see what happends. thanks for all the information you gave.
Old Oct 22, 2005 | 04:24 PM
Shogunsc4's Avatar
no problem. Let us know how it goes.
Old Oct 22, 2005 | 05:19 PM
BewstAdd1ct's Avatar
did you tighten all the clamps?
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
