Question: Climate control lights are out
Old Oct 22, 2005 | 11:55 PM
RR5's Avatar
RR5
Suddenly my climate control units Air Recirculation button, the red/blue temperature bars and the A/C button all are not lit when the headlamps are on.
I pulled out the radio and the climate control unit and so far was unsuccessful in trying to get access to the climate control unit. I'm going to have to fight with the radio's screws that hold it to the mounting bracket as they are on there VERY tight.
Is replacing the light bulb in there going to be easy? Or should I just take it in and get it done the easy way?
Many thanks.
Old Oct 23, 2005 | 05:01 PM
JD2k2's Avatar
What year is your Max?
Old Oct 23, 2005 | 06:43 PM
Peabo5000's Avatar
Hey I have a 2k2 se with similar issue. The fan light and the first 3 top buttons do not light up. But everything else is cool.
Old Oct 23, 2005 | 07:27 PM
RR5's Avatar
RR5
I have a 2002. Unfortunately, I think the LEDs that light up the buttons and what not are directly soldered onto the PCB.
Side note, anyone replace the factory non-bose radio with a single DIN unit and have those gaps on the left/right side of the radio?
Old Oct 24, 2005 | 05:25 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I would answer this question, but it's the third fawking time this question have been asked in a week. Try searching the forum some more, you can find my answer there.
Old Oct 24, 2005 | 08:48 AM
bugbite77's Avatar
yes, very small gaps though
Old Oct 24, 2005 | 09:29 AM
RR5's Avatar
RR5
So there is nothing aftermarket or OEM that will accomdate a single DIN mounted in the factory dual din location?
Old Oct 24, 2005 | 09:36 AM
Yeah, there are 4 or 5 different mounting kits. Metra, Schosce, look around
Old Oct 24, 2005 | 10:56 AM
bugbite77's Avatar
im not sure what kit i have but it has a little pocket shelf under the after market head unit.
Old Oct 24, 2005 | 10:59 AM
GBAUER's Avatar
Holy thread hijacking Batman! Lights to search comment to aftermarket radio post!?!?
Old Oct 24, 2005 | 12:44 PM
RR5's Avatar
RR5
Thank you for all your help
http://www.autotoys.com/x/catalog/NI...IT_p_1767.html
Now about the lighting on the climate control unit? Just pop it open and take a look?
Old Nov 1, 2005 | 12:56 PM
RR5's Avatar
RR5
Yeah there are three little "button" type LEDS that are behind the PCB of the climate control. Really easy to remove and they cost about 5-10 dollars per bulb at the stealership.
Old Nov 1, 2005 | 01:09 PM
Just so you guys know, the 3 bulbs that illuminate the climate control are NOT LEDs.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
