Does it play CD-RW
Old Oct 24, 2005 | 10:10 AM
takkar's Avatar
Does it play CD-RW
Hey Guys,
Do you know if the stock Bose HU for 01s play CD-RW.?
Thanks..
Old Oct 24, 2005 | 10:26 AM
TrojanMan2116's Avatar
yes it does
Old Oct 24, 2005 | 10:27 AM
takkar's Avatar
thanks Trojan...for some reason, the HU shows ERR and it spits it out. But the CD works on the computer.
Will have to try some other things out..
thanks
Old Oct 24, 2005 | 10:31 AM
UGAd13's Avatar
thanks
Try a different or better brand. I noticed that happens on the crappy cds sometimes.
Old Oct 24, 2005 | 10:38 AM
Progress's Avatar
It's business time.
Too bad my headunit plays CD-Rs but it plays them with a tick sound.
Old Oct 24, 2005 | 10:53 AM
TXT-1's Avatar
Also try cleaning the CD player. CD-RW's are extra sensitive to dirty optics.
Old Oct 24, 2005 | 10:55 AM
ColdSHO's Avatar
cd-r's and rw's are less reflectivet han a normal nonburned cd, so its harder for a player to read them cdr's arent a problem most of the time beacuse since theyre only burned once theyre pretty reflective, but cdrw's get reburned over and over so they are noticbaly less reflective and harder for players to read, even if uve only burned on them once.
cheaper cdr's n rw's are less reflective then the more expensive ones, notice how some are $$ while u can get like 100 for like 5 of the cheap ones, the cheap ones use a well cheap film thats not as reflective and can flake off inside a player, that would be bad. as it can conduct electricty and heat rather well
Old Oct 24, 2005 | 11:10 AM
NYPD-Arnold's Avatar
Z
No it doesn't. For the 4 years I've had my car, it never once played a CD-RW and I only have Memorex here. What brands do you guys use for it to work? I really don't think CD-RWs work in 5th gens.
Old Oct 24, 2005 | 11:16 AM
takkar's Avatar
I usually use no name brands for CD-R and it works fine..never had an issue
Tried Imation's CD-RW and it doesnt work
Old Oct 24, 2005 | 11:26 AM
boondoxmax's Avatar
never had a problem with my non bose in my 02 playing cd-r. My bose in my 03 also plays them with no problem
Old Oct 24, 2005 | 11:42 AM
chr0nos's Avatar
i think most headunits have problems with cd-rws. because they are cd-rws.
Old Oct 24, 2005 | 11:46 AM
Progress's Avatar
It's business time.
Please note the discrepancy between CD-Rs and CD-RWs.
Old Oct 24, 2005 | 11:47 AM
Progress's Avatar
It's business time.
How do you clean it?
Old Oct 24, 2005 | 11:55 AM
TXT-1's Avatar
http://shopper-search.cnet.com/searc...-cnet&tag=6344
Old Oct 24, 2005 | 12:25 PM
Progress's Avatar
It's business time.
Thanks, do you have to use the automotive one or do the regular ones work?
Old Oct 24, 2005 | 12:45 PM
TXT-1's Avatar
I use the Maxell one made for autos. I think you just have to make sure it is either designed for slot systems or drawer systems like in home stereo stereos.
Old Oct 24, 2005 | 01:42 PM
igzy's Avatar
I Know Kwaliti
Also try burning the CDs at slower speeds. I tipically burn them at either 4X or 8X... Do not use any brush based cleaning things as they may scratch the laser lens... Best is if you can open it and spray with a cleaner and leave to dry... Brake cleaner would do too... They leave no residue...
Old Oct 24, 2005 | 02:36 PM
designer485's Avatar
My bose in my 01 does not and has never been able to play cd-rw's. I see one solution, use cd-r's.
Old Oct 24, 2005 | 03:03 PM
Progress's Avatar
It's business time.
Did you buy it online or can you get it at a store?
Old Oct 24, 2005 | 03:33 PM
TXT-1's Avatar
Bought it at Best Buy...
Old Oct 24, 2005 | 04:36 PM
Progress's Avatar
It's business time.
Nice, I appreciate it. Since I switched back to the Bose HU, it's bothered me that I can't play burned discs without hearing that clicking noise. I hope cleaning the lens works.
Old Oct 25, 2005 | 11:21 AM
jreddington3's Avatar
I have nav system with the 6 disc changer in the trunk. This system has had no problems with CD-Rs. However, CD-RWs work maybe a quarter of the time. I can't find a pattern and have tried using different brands and burn speeds. Only pattern found is that it seems to be the individual disk, not the burn. If a disc works once, it usually (note ususally, not all the time) works even if re burned several times. If it doesn't work the 1st time, reburns of that same disc won't work either.
Old Oct 25, 2005 | 12:45 PM
kobalt's Avatar
Make sure the cdr is "closed" meaning you cannot burn more data to it. Some HU have problems playing "open" cdrs.
Old Nov 5, 2005 | 03:46 PM
BruceB's Avatar
My '03 Bose plays them and displays artist and track info that an original CD does not.
Bruce
'03 SE Sheer Silver
Old Nov 5, 2005 | 04:10 PM
Z
I've cured my clicking problem: keeping the CDs free of scratches. The Bose HU is INSANELY **** with even the most lightly scratched CDs. Once I noticed this, I've began to make sure all of my CDRs are always carefully stored in a case -- and not a CD wallett where they WILL get scratched.
Old Nov 5, 2005 | 05:53 PM
Army of Maxima's Avatar
Looking for a few good Maximas
That's funny... they've been working in mine just fine for 2-1/2 years now.
Old Nov 5, 2005 | 05:54 PM
Z
You have a 2003...
Old Nov 5, 2005 | 07:26 PM
VQ30GTR's Avatar
You must "close" the session. The car needs to see the beginning and end of the CD, or you get errors, and it has no idea where the music is.
Old Nov 5, 2005 | 08:21 PM
AceofSpds's Avatar
wat
have you guys had problems w/ the cd player in the car scratching up your cds? mine is really bad about scratching up the disks.
Old Nov 5, 2005 | 08:45 PM
LA02MAX's Avatar
the reason yours doesn't work is because it the files on it are most likely MP3's, which our CD players are incapable of playing, unlike a computer.....i have had no problems whatsoever with any of my CD-RWs in the past, except for one of my friends CDs, which was an MP3 CD..
Old Nov 5, 2005 | 10:54 PM
JD2k2's Avatar
Only CD-R's i've ever had a problem with are Imation, CD-RW's work maybe half of the time if that.
Old Nov 6, 2005 | 05:13 PM
AceofSpds's Avatar
wat
I bought one of those eye cleaner disks today and guess what? My cd player wont read it! i get the ERR, the cleaner disk has some kind of info on it that im supposed 2 listen 2, i took the disk after it spit it out and i looked at it the disk was scratched up! I was sitting in a parking lot with the engine off.
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 6, 2015 02:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Andy29
Sep 29, 2015 05:32 AM
vrajesh123
Sep 22, 2015 04:20 AM
