View Poll Results: Have your brake lines broken before?
Yes, I have a 2k-2k1, and they have previously broken
3.75%
Yes, I have a 2k2-2k3, and they have previously broken
2.50%
Yes, but I have a different gen maxima
1.25%
No, they have never broken
74
92.50%
Voters: 80. You may not vote on this poll
Old Oct 26, 2005 | 02:50 PM
Nathan's Avatar
I am curious to know whether anyone with a 5th gen: 2k-2k1 or 2k2-2k3 has ever had their oem brake line break?
The other day I was driving at school, as I was approaching a red light I went to brake, had almost no brakes, but was able to safely stop. I looked at my front drivers side rim and it had brake fluid on it. After towing it home, it seems like the rubber line burst. Cubanato & Kloogy also have/had their 2k2 brake lines break.
Anyone else? If so, at what mileage? Please choose from one of the above poll options. thx
Nathan
Old Oct 26, 2005 | 03:00 PM
MaximaPolak's Avatar
My friend's (Cubanato's) burst recently. Makes me want to get the SS Brake lines. Mine have not burst yet.
Old Oct 26, 2005 | 03:29 PM
PoLo's Avatar
2-Wheelin it...
voted no. currently at 34k miles.
Old Oct 26, 2005 | 03:55 PM
upstatemax's Avatar
Just a ??? how heavy are your rims?
If you throw on big heavy rims and tires, it puts much more stress on the braking system... over time I would think the extra force needed to stop would over stress the rubber OEM lines and cause them to fail....
If I had bigger heavier rims, I would switch to SS Lines just to be safe.
Old Oct 26, 2005 | 04:01 PM
Nathan's Avatar
Both mine and Cubanato's rims are around 24lbs for a 19" wheel. Doesn't seem to be excessively heavy.
Old Oct 26, 2005 | 04:08 PM
upstatemax's Avatar
No its not that heavy, as a matter of fact I think the SE 17's are around 26lbs. guess thats not the cause then
Old Oct 26, 2005 | 06:47 PM
irish44j's Avatar
retired moderator
ummm....probably not the lines breaking, but instead probably got some road debris of some sort kicked up into the wheel well and cut the line...it happens. The lines aren't going to break just from "braking"....
Old Oct 26, 2005 | 06:58 PM
nicks79's Avatar
That makes no sense. What does wight have to do with it? I's say lighter wheel would stress suspension more, cause its takes less potential to move lighter wheel. So the acceleration on wheel movement up and down would be higher.
mine at 112k are still good.
nadeemp8's Avatar
I have 94K on my '01 and haven't had a problem....yet.....
Old Oct 26, 2005 | 08:30 PM
irish44j's Avatar
retired moderator
in all fairness to the other guy, this doesn't make any sense either. The wheel weights have no appreciable effect on the brake lines. Neither does hard driving. Go to any autocross and you'll see that most guys actually run rubber/OEM brake lines over SS lines because they are LESS likely to fail. SS lines are for "pedal feel" only, not for reliability. SS lines (realistically) should be changed out for new ones every few years, as they have a tendancy to chafe internally (and externally) and fail without warning if not maintained properly.
There is a great, detailed explanation of the "downside" of ss lines someplace, but I can't seem to find it....here's a paraphrase of what it says:
Originally Posted by paraphrase of what it says
One downside to using stainless braided lines is that the outer braiding is usually more wear fragile than the stock rubber hose. If the line rubs on a shock or other nearby surface, the braid may eventually wear and split open. The braid provides much of the strength of the line so when it does tear there is danger of the inner lining bulging outward, which may lead to complete failure of the line.
basically, a rubber line will often have a small leak when it starts to fail, resulting in spongy pedal, air in the system, etc....but enough advance-warning to fix the problem before an accident ensues. When SS lines go bad, they do it FAST....no warning signs whatsoever.
another one (though the link mentioned is dead):
Originally Posted by 442 forums
Stainless Steel Braided Lines/Hoses
If you go with braided stainless steel (SS) brake hoses, you should plan on replacing them every year. If you do not plan to do this annual replacement, then you should not install braided SS hoses on your car. That being said, I strongly urge you to read the following webpage on this subject:
http://www.olympiakos.com/svt-faq/node21.html.
This page explains a lot about braided SS brake hoses, which are really Teflon lines with a SS braid around the Teflon. The Teflon has advantages over rubber, but these brake lines are not bulletproof.
Here's some quotes from the above mentioned webpage:
"Here's the thing, though: Since stainless-steel lines don't bulge as they age, and since the inner Teflon lining is hidden behind the braid, there's no easy way to inspect the lines for warning signs of imminent failure."
"This is no big deal on a race car, since the lines are (or should be) replaced at least once a season. On a street car, where most people are likely to let YEARS go by without even looking at their lines, it can be an issue."
"When steel-armored hoses were run through a test, it was found that the hoses tended to bend right at the junction between the hose and the hose-ends. After a while, the stainless-steel braid would start to tear, and the broken wires would cut into the inner Teflon liner, causing it to fail."
I have seen other postings on a different car forum where people have seen this same type of failure - over time the steel braid cut through the Teflon brake line.
So, again I urge you to read that webpage, and be fully informed before you consider whether stainless steel lines are right for your car. Brakes are no place to cut corners, so if you don't want to make the commitment that SS lines require, then you should stick with rubber, IMHO.
This is why I have rubber lines on my fronts, and never installed my SS lines...though I do have them on the rear, where they are less likely to chafe and be unduly stressed.
Old Oct 26, 2005 | 10:05 PM
Nathan's Avatar
But in my case, I had absolutely no warning signs whatsoever with the oem line going. It all of a sudden gave way and I lost just about all my braking. I will snap pics of the damaged line so I/we can get a better idea of what happened here.
Old Oct 27, 2005 | 12:48 PM
2kprlmax's Avatar
havent had a break in my lines 85K but i am going to change to the ss lines this winter.
Old Oct 27, 2005 | 05:14 PM
upstatemax's Avatar
You are saying I make no sense??? Wow
I respect Irish's opionion and all, however, I think many of you guys discount the effect heavy rims have on a car...
My brother is a mechanic and has been for a long time, he feels; the extra rolling mass is harder to stop, duh. This increases the temperatures your breaks get to and you have to push harder on the pedal to get the extra force to stop, increasing force. The addition of heat and force can wear down parts quicker causing higher failure rates.
Some of the rims people are throwing on have a total rim and tire mass of 10-15lbs heavier PER CORNER.... Thats like throwing 250-350lbs of weights in your car and telling me that it takes the same ammount of force to stop the car. All of you know the effects it has on acceleration, why would it not hurt breaking the same way... think about it.
Old Oct 28, 2005 | 04:20 AM
nicks79's Avatar
Now listen to yourself. How is 15 lbs heavier wheel per corner equal to same as throwing 250-300 lbs of weights in the car? Last time I checked there is 4 wheels in my car that would equal approx. 60 lbs of extra weight.
If you have light wheels combo and heavy load in the car or no load in heavy wheels, assuming all wieghts are equal - then it takes the same amount of work for breaks to stop.
Are you saying that driving with the passanger is not good for the breaks? Of course not, but the car was designed for 5 people so it better keep up.
If you want to preserve your breaks in the best working condition, make your car as light as possible. But if you think that the weight of wheel ITSELF makes the difference - and not the total mass, then I suggest Physics 101. No offense.
Old Oct 28, 2005 | 07:21 AM
upstatemax's Avatar
Because rotational mass effects a car more than putting something IN the car!!!
For every pound you add to the wheels or rotors, it is like adding 6-8lbs to the car. Before you try and act smart at least know SOME of what you are talking about.
Old Oct 28, 2005 | 07:37 AM
nicks79's Avatar
Prove it...
Old Oct 28, 2005 | 08:28 AM
Jasovanni's Avatar
Um, hate to add to the confusion here, but there is another factor involved. Keep in mind that larger rims, even if not heavier AT ALL, will slow a car down. This is also due to the rotational mass/inertia being described above. The ratio may not be much, but yes, effect on acceleration is greater, (by at least 2:1) when reducing rotational weight vs. overall weight. What is being disregarded by nicks above, is that the farther rotational mass is from its axis, the more energy it takes to move that mass.....hence making reducing THAT weight, more effective.
The following information was borrowed from another site, found by googling for rotational mass:
I figure 1# off the wheels is about 2# off the chassis:
Notes from physics --- Kinetic Energy = 1/2 I w^2 where
I = MxR^2 ... R being the radial center of mass, w is rotational speed,
which for a 24"; tire is 1.0xspeed in ft/sec...
use slugs for M (lbs/32.17) if you want to stay in the ft/lb/sec system and
lets you easily figure out hp (550 ft.lb./sec) to spin up to a given speed in
a certain # of seconds).
I crunched some numbers for a reality check.
For my wheel tire combo (SSR 16x7 GT1 - 15# and
BS SS-03 205/60/16 24#) it would take about
6 hp to get the 4 tires spinning to 60 mph in 7 seconds
and to accelerate them linearly to 60 mph as well, and it would take a 50# combo about 9 hp to do the
same... and takes about 78 hp (average) to propell the
remaining 2500 pounds of car and driver from 0 to 60 in 7 sec.
This doesn't include extra horsies to overcome rolling friction
and air resistance.
From these numbers, 1# off at the wheel is about as good as about 2.2# off the chassis
3 hp difference for the 44# wt savings from 39# to 50# per wheel, compared with
3 hp difference for 96# at the chassis. 78hp for 2500# chassis vs 81 hp for 2596#
chassis to do the same 7 second 0-60.
Some approximations were used (like the precise location of R).
Your results may vary.
Hope this helps!
J
Old Oct 28, 2005 | 08:32 AM
NisMoN00B's Avatar
+Cru OG
75k and no problems with my OEM rubber hoses.
Nick & UpstateMax...is the debacle based on a car with OEM brake system or no? With the brake effect, has the speed of the vehicle placed into the equation as a variable for stopping?
Old Oct 28, 2005 | 11:42 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
You know whats sucks even more.....the bolt where the rubber hose connects tothe rubber hose stripped on me yesterday while i was tyring to get it of.....im hoping tonight i can get it off with some vise grips. This maxima had been nothing but problems and i still can't even take my car to the movies cuz of teh damn headlights
-J
Old Oct 30, 2005 | 02:12 PM
Y2k2maxse's Avatar
i had 120,000 miles on my 2K and i didnt drive it easy by any means...ABS kicked in a LOT for how heavy i Braked at times. The car was flawless and it stopped on a dime. never had any break line problems. My 2K2 with 36K also has no problems.
Old Nov 29, 2005 | 09:55 PM
NmexMAX's Avatar
dot dot dot ...
Why .. they might get stolen?
Old Nov 30, 2005 | 05:58 AM
silviaguy
I voted no. I have heard about this problem and with 81,000 miles on the car I didn't want to wait till something happened. So I swapped out my rubber lines for some stainless steel lines. Better safe then sorry.
I still have my old rubber ones if anyone has a dead wish...
Old Nov 30, 2005 | 07:53 AM
Mark2's Avatar
I voted no... I haven't heard of this problem on Maxs. However, I did have a brake line break on an old Honda of mine. There was lots of warning... spongy brakes, rotor creaking noises... that's what lead me to pump the brakes in my driveway when I broke one front brake line hose... after that, I replaced all four. It seems a little early for our Maxs to have problems with brake hoses... do you possibly have enemies or Maxima envious/jealous neighbors?
Old Nov 30, 2005 | 09:18 AM
zoner's Avatar
I voted no - 125K on the OEM lines
Old Nov 30, 2005 | 12:01 PM
spirilis's Avatar
Prove it...
I've seen that figure (1lb unsprung mass is equiv to ~6-8lbs sprung mass) quoted a lot. You could probably do us a favor by proving it yourself, or finding supporting documentation online. From my perspective at least, it's an accepted piece of knowledge.
Old Nov 30, 2005 | 02:28 PM
zoner's Avatar
Not to get off subject, but I did get heavily interested in the '6-8 lb reduction' when I thought about the possible effect this could have on accelleration and handling. I found many claims of the 6-8 lb reduction per lb of wheel weight, but no calculations...
I did find this link in the Audi World forums regarding rotational inertia - it's alot of math, but I couldn't find any errors. I'm not saying it's right, but it's about all I've found with something detailed behind it.
http://forums.audiworld.com/s4/msgs/1032814.phtml
Old Nov 30, 2005 | 02:55 PM
wojowojo16's Avatar
Nathan
yup, turns out the brake line bracket (on the strut) was not connected properly and the rubber line rubbed on the strut and blew...scared the **** out of me...lol
Old Nov 30, 2005 | 06:43 PM
k2max_driver's Avatar
My SS rear lines both went out when they rubbed on my sway bar bolts. replace them with stock ones but i seem to have no problem with the fronts
Old Jun 1, 2006 | 03:43 AM
sciff5's Avatar
Damn it...how could that happen?? Thats one of the main reasons I am getting rid of the oem lines is because I couldent imagine a ss line being effected as much by my RSB bolts.
Either way though I hate the way my brakes feel and I would still get ss lines just to get rid of the spongy pedal
Old Jun 1, 2006 | 11:37 AM
Edward Lee's Avatar
If you have changed out your brakes you may have twisted the line when you put your caliper back on.
Old Jun 1, 2006 | 12:13 PM
MaxKlinger's Avatar
I've never had a brake line fail on either of our Maximas. The '96 and '02 have 227,000 and 104,000 miles respectively, both on original brake lines.
Old Jun 1, 2006 | 07:44 PM
foodmanry's Avatar
Da Roller Coaster!
I had a S/S line fail on me. But it was due to improper mounting and the lne was resting on a portion of the rotor that heated through the SS eventually wearinig it out. Luckily it busted while I was working on my car in the garage.
Old Jun 2, 2006 | 06:26 PM
maxS
why bother with oem lines. replace them with these:
Old Jun 3, 2006 | 10:27 AM
foodmanry's Avatar
Da Roller Coaster!
Go back and read Irish's post. It actually makes me think twice about my S/S brake lines...especially after I had one fail already (due to operator error...woops!)
Old Jun 3, 2006 | 10:46 AM
96blkonblkse's Avatar
i have 3 maxima's, 02 se wtih 50k miles, never broken a brake line, my black 98 with 117k miles never broken a brake line, my 98 5spd with 182,000 miles has never broken a brake line either, as well we have 4 other maximas in the family, a 91 which has the original oem lines, another 02 and 03 which all have original lines, and a 01 which has the originals too. could be a one off problem, ive never experienced it myself, someone could have twisted the brake line when they were doing the brakes or damaged the line and weakened it.
Old Jun 3, 2006 | 01:53 PM
Mass_Media's Avatar
Mass_Media™
Makes me kind worried about my ss brake lines. They are only a few months old i guess i will just have to make sure i replace them every year or so.
Old Jun 5, 2006 | 04:15 PM
maxS
ok... why would then these lines be included with $2k+ brembo bbk? C&D did not mind using them in their brake kit tests too
Old Jun 5, 2006 | 04:39 PM
Edward Lee's Avatar
You're kidding, Right? SS lines will last you a lifetime.
This guys brake line failure was probably due to him or someone twisting the line when they reinstalled the brake caliper. It's an easy thing to overlook when doing your brakes.
Old Jun 30, 2006 | 05:07 PM
VaporHead
Duct tape and zip tie fix anything.
Old Jul 10, 2006 | 03:51 PM
03on18s's Avatar
i had a stainless line blow after about 10k. i've gone back to oem all around and have had no problems.
litch
123
Jan 4, 2024 07:01 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
