Trans Flush
Old Oct 30, 2005 | 02:03 PM
Y2k2maxse's Avatar
Trans Flush
It was recommended when I got my oil changed that I get a tranny flush, They say they use some kind of pressure thing to 100% flush it than put new fluid in. Is this OK to do? somewhere I thought I heard this is bad and can screw up the tranny. But I need to get it done. true or false? (BTW only reason why I dont change my oil myself is cuz of the stupid extended warranty which requires proof of a professional oil change)
Old Oct 30, 2005 | 03:54 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
your extended warranty will be alright even though you do it.. but in case you change your mind.. follow mi sig.....
Old Oct 30, 2005 | 05:42 PM
Y2k2maxse's Avatar
so if I get it flushed...it will be more responsive? as in what? quicker shifts?
Old Oct 30, 2005 | 06:04 PM
dubious's Avatar
I took mine to one of the local lube places to have mine done the other day -
instead of pressure flushing, they
drained
pumped in new fluid -
ran car to mix converter leftover,
drained again,
filled/mix again
repeat 3 or 4 times....
didn't drop the pan or change filter, and it's probably not as good as a complete flush...but i figure it's better than worrying about the pressure systems screwing up seals.
Just didn't have time to do it myself, so figured this was better than nuthin...
Old Oct 30, 2005 | 06:09 PM
Lontar1's Avatar
not as a huge difference but I felt it more responsive than before.....
Old Oct 31, 2005 | 05:48 AM
boondoxmax's Avatar
drained
drained again,
filled/mix again
When i had my auto the dealer did the pressure thing. It gets all the old fluid out. Its the best way to go and it doesn't mess up seals.........I didn't really notice that much of a differences.
Old Oct 31, 2005 | 06:29 AM
ao3dave1994's Avatar
Di mine at Midas, set it on low and just pumped fluid, no chemicals were added as normal. I just slowly flushed with 13 qts. Car runs fine.
Old Oct 31, 2005 | 07:01 AM
Bobo's Avatar
What is the mileage on the car? You should have done a drain and fill at 30K, followed by a flush at 60K and repeat process every 30K.
Old Oct 31, 2005 | 10:13 AM
danger300z's Avatar
i do mines every 10k and its simple as changing your motor oil.
Old Oct 31, 2005 | 12:06 PM
silviaguy
maybe I should get this done on my car.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
RWCreative
Sep 21, 2015 11:01 AM
